Painting Aluminum Siding On A Mobile Home
Old 03-26-2008, 10:32 AM   #1
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
I don't paint much aluminum siding but I have read different opinions (from paint manufacturers) re: priming or not.
I am doing a small job on the exterior surface of a mobile home, most of which is aluminum siding.
The aluminum siding is prepainted with a god awful yellow and the client wants to go with white satin or semi gloss.
My gut tells me to do the appropriate prep (wash, clean, sand, etc) and prime with a Zin 123 followed with 2-3 coats of exterior latex (100% acrylic) paint.
However, other reliable sources have suggested no primer, just do appropriate prep followed with 2 coats of white exterior oil paint.
What has worked best for people in the past?? Use a primer?? Latex Paint?? or Oil??
Thanks
Zeebo
Zeebo is offline
Old 03-26-2008, 11:29 AM   #2
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
Re: Painting Aluminum Siding On A Mobile Home
I would do the clean and sand part, Then Kilz over with oil based. Then use your color choice. I'll pretty much tell you now, it's gonna end up looking like crap either way you go.
I had a customer last month wanting the same sad paint job. When i finished she looked at it and said, " OK, rip it all off and put vinyl all the way around.
Now it's a lovely shade of tan in quality vinyl.
She paid twice, but she is happy now.
"If you start the grout process over, you too could use sparkly grout!"
There is no such thing as an illegal immigrant, they are either illegal or immigrants.
I'm Retired, or a student, don't really know anymore.
wizendwizard is offline
Old 03-26-2008, 12:02 PM   #3
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
Yes thanks. I'm worried about this one too. I advised the client to buy some sample paints and apply to siding so she can get a true sense of color...she wants all white with black trim. Painting white is a pain in the ass...never enough to do just 2 coats... probably 3-4. That's why I'm thinking a primer to not only cover the undercoat....but to help with paint adhesion.
I was always of the belief you had to use a primer on top of aluminum siding (already painted)...but from what I have been reading in the posts....primers are not needed....just use a good quality acrylic latex.
Zeebo
Zeebo is offline
Old 03-26-2008, 01:59 PM   #4
I'm not sure zeebo but I think they use electro bonding when they paint the factory color on the old aluminum siding used on mobile homes.
If the HO is really wanting to go with the paint i'd do some test on 1 piece of it with different samples until I got a result I could live with.
Old 03-26-2008, 05:35 PM   #5
Veith@toast.net's Avatar
Trade: Painting and wallcover
Rewards Points: 75
I Normally power wash all chalk off Add some E-B my first coat. Then reshot it with straight paint. Been doing it this way for 25year and as far as I know have had one that had a spot here it gave me headaches. You basically don't want to use any E-B in your top coat. But if I have a little left you know like a 1/2 gallon and plan on using a 5 for top I just mix it in.
David Enterprises
Painting Contractor
Veith@toast.net is offline
Old 03-26-2008, 06:21 PM   #6
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
Thanks for all info and suggestions
Zeebo
Zeebo is offline
Old 03-26-2008, 08:36 PM   #7
semi-skilled laborer
ModernStyle's Avatar
Trade: Professional Painting
Rewards Points: 1,186
Would there be a difference between painting an aluminum trailer and a house with aluminum siding ? I have never had to prime a house with aluminum and have never had any bonding issues. I always just wash and paint.
OwensboroPainting.com
ModernStyle is offline
Old 03-26-2008, 09:49 PM   #8
REGAL PAINTING
regal's Avatar
Trade: painting contractor
Rewards Points: 150
agree , wash and paint never an issue
regal is offline
Old 03-26-2008, 10:31 PM   #9
Allrounder Home Services
EricTheHandyman's Avatar
Trade: Residential Remodeling
Rewards Points: 250
http://www.paintquality.com/ppp/exterior/alum1.html
EricTheHandyman is offline
Old 03-27-2008, 08:06 AM   #10
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Wash and paint should be fine if using a good quality acrylic. Forget oil on aluminum. Aluminum and oil do not get along well. The main issues is to make sure you get all the chalking off. If chalking is a huge issues, E-B or Zinsser Peel Stop may be needed to bond any residue prior to painting. XIM Peel Bond would work too but it's really overkill for chalking.
gideond is offline
Old 03-27-2008, 10:52 AM   #11
Frankawitz's Avatar
Rewards Points: 1,196
Zeebo, Check Benjamin Moore's IronClad paint it's a self priming paint two coats. I would power wash then scubb down with TSP and risen down with a hose make sure all TSP is gone, Then let it dry over night and come back next day mask off all areas not being painted and spray it out two good even coats of the IronClad you should be good.
www.frankawitz.net
Frankawitz is offline
Old 03-27-2008, 02:31 PM   #12
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Rewards Points: 250
Send a message via Yahoo to painterofeveryt
is ironclad an oil based product ?
painterofeveryt is offline
Old 03-28-2008, 06:50 AM   #13
Frankawitz's Avatar
You can get it in oil or latex finishes are stain, and semi gloss, I believe.
Old 03-28-2008, 09:58 AM   #14
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
Thanks for all suggestions re: methodology and product...very helpful. I always thought that priming was the way to go but it is obvious that I don't have to do this if I use the 100% acrylic paint (with obvious good prep and cleaning)
Thanks Again.
I will research the BM product.
Zeebo
Zeebo is offline
Old 03-28-2008, 03:47 PM   #15
paintr56's Avatar
Trade: paint contractor since 1974
Rewards Points: 250
I spray a lot of aluminum siding. I power wash, paint first coat with Emalsa Bond added one quart to the gallon to 100% acrylic latex, and then a second coat of straight 100% acrylic latex. I agree with Veith@toast.net I will mix a little left over in with the paint for the second coat but not too much. There is no advantage to this other then using up your paint. The problem with E-B in the second coat is the E-B can cause flashing.
Jim
paintr56 is offline
Old 03-29-2008, 08:55 AM   #16
gideond's Avatar
It can also accelerate chaulking. We use to sell a lot of Flood solid stain with the E-B built right in. After a while a lot of customers started complaining that it would chalk rather quickly, within a couple of years.
gideond is offline
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 07:02 PM
Home Depot now offering painting Frankawitz Painting & Finish Work 22 07-14-2007 10:28 AM
Set up at a Home Show Today... Max10 General Discussion 16 10-18-2006 03:03 PM
Vinyl over aluminum? Sal616 Windows, Siding and Doors 6 02-20-2006 08:37 AM
