Painting Aluminum Clad Windows
Old 06-08-2006, 08:44 AM   #1
jeffkaprelian's Avatar
Trade: General
Are there any special precautions for painting the aluminum cladding on windows. I'll be going from white cladding to a mustard color. Any special primers to use? They are Pellas btw. Thanks.
jeffkaprelian is offline
Old 06-08-2006, 12:17 PM   #2
simmons's Avatar
Trade: painting
Re: Painting Aluminum Clad Windows
jeff-
I just did a job repainting pella architectural series windows. The touch-up paint was supplied by cardinal industrial finishes. They have six locations around the country.
The factory finish I was told is baked on. The solvents on the paint delivered to the job were methyl isobutyl ketone,methyl ethyl ketone,acetone,isobutyl acetate among others.
If it is not possible to acquire the paint through cardinal I would suggest using Xim urethane modified primer after degreasing(using a solvent based degreaser) and sanding 220g.
good luck
simmons is offline
Scouring Pad for Cleaing Windows WNYcarpenter General Discussion 23 08-05-2009 01:22 PM
Painting Aluminum theartisan Painting & Finish Work 9 05-23-2007 02:37 PM
Painting Aluminum Siding Larman Painting & Finish Work 18 04-28-2007 12:05 AM
Condensation on windows skidmark845 Windows, Siding and Doors 20 02-12-2007 08:59 PM
painting unfinished new windows Traditions Painting & Finish Work 3 10-30-2006 09:11 PM
