Old 05-15-2007, 09:36 AM   #1
Trade: repairs, maintenance, improvements
Painting Aluminum
Any advice from the painters for painting an aluminum storm door? This is my MIL's door, and she wants it painted It is showing UV bleaching/discoloration. I am more inclined to replace it, but she asked if I would paint it for her.
TIA
theartisan is offline   Reply With Quote
Old 05-15-2007, 10:29 AM   #2
painterofeverything
Trade: residential painter
Send a message via Yahoo to painterofeveryt
if it was my door..would scuff lightly with a green scuff pad,wipe it down and shoot it with an airless sprayer tip size .409 or a .411 .
painterofeveryt is offline   Reply With Quote
Old 05-15-2007, 04:19 PM   #3
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Spraying would be ideal, but might not be worth the cleanup hassle. Brush/Roll will work fine.
If you are looking for products to use. BM DTM, Zinsser 123, and SW Bonding Primer are all good products for aluminum and for this project.
Good luck
Rich
Richard is offline   Reply With Quote
Old 05-16-2007, 12:20 AM   #4
Ya some of you guys amaze me with your fixation on spraying for only one door. The set up and cleaning would take twice as long as brushing and or rolling.
Woz the Painter is offline   Reply With Quote
Old 05-16-2007, 04:48 AM   #5
painterofeverything
woz,it is his mother in laws door and it was only the way I would do it,please post your own advice,Thank You
Old 05-16-2007, 07:22 AM   #6
I'm not planning on spraying, just b/c I hate cleaning my sprayer. I was more concerned about paint adhesion. So thanks paintguy, I'll grab some SW bonding primer. I am still going to try to convince her to replace it just b/c its less time consuming for me and its pro-bono work.
Old 05-16-2007, 09:34 AM   #7
Use the best. XIM 400W bonding primer. You really don't want to go back to your mother-in-laws to fix it if it starts peeling much less hear about it at every family gathering. Sounds like a critical application to me.
Tommy Boy is offline   Reply With Quote
Old 05-17-2007, 02:56 PM   #8
Sarcastic Prick
Trade: Paint and Floor Covering Retailer
If there is any chalking or peeling, I'd use something like Zinsser Peelstop, a clear bonding primer. Then I'd use a good hard DTM. Sampson actually has one of the best DTM products I've used. It's called Weatherbrite and has a very hard durable finish with a good gloss, but not a high gloss. It's speced for roofs.
gideond is offline   Reply With Quote
Old 05-18-2007, 08:50 AM   #9
That'll Buff Out
ModernStyle's Avatar
Trade: Professional Painting
I keep a $20 Hvlp around for small stuff like that, I never tear it apart and clean it, just rinse it with thinner a few times after each use. If it breaks or clogs too bad I just replace it, I always seem to get my moneys worth out of them and it is alot easier then cleaning up my good equipment.
ModernStyle is offline   Reply With Quote
Old 05-23-2007, 01:37 PM   #10
MFWIC
Trade: house painter
An automotive cup gun works dandy for an aluminum door. Scuff the loose stuff, wipe it down w laq thinner, blast it w DTM. no primer dtm is dtm ! re-install next day r
Tmrrptr is offline   Reply With Quote
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 15 12-23-2008 11:46 PM
Aluminum to copper lug Mike Finley Electrical 21 06-02-2007 11:31 PM
Painting Aluminum Siding Larman Painting & Finish Work 18 04-27-2007 11:05 PM
Another aluminum wiring question ron schenker Electrical 18 03-08-2007 06:54 PM
Painting Aluminum Clad Windows jeffkaprelian Painting & Finish Work 1 06-08-2006 11:17 AM
