Painting
Old 10-29-2009, 08:36 AM   #1
dsmith11542's Avatar
Trade: Property Management
Painting
Can I paint a forever door?
dsmith11542 is offline
Old 10-29-2009, 06:02 PM   #2
House Painters Reading PA
4thGeneration's Avatar
Re: Painting
Every surface you paint has to be
Dulled:Scuff sand it. Get something in the higher numbers like very fine paper you use on the cars. You do not want to sand off the vinyl. You just want to rough it up a bit.
Clean:You can use a spray bottle that you can buy from the dollar stores. Use bleach, Dawn and some soap powders for a quick fix. This will need to be soft brushed clean after you let it dwell like 5 minutes.
Dry: I would wait a couple days to dry out. Also now that winter is coming on, I would only paint it like after 11Am or so and not past 3PM.
Coating:Resilience by Sherwin Williams. Use the Satin finish, but build it up if by brush. If you are handy with a spray gun, you can take it off and onto saw horses. cover the area beneath it and tape off any hinges or door knobs that are not to be painted. I would apply a few coats to it. Do not try and cover it in 1 shot.
This is one way you can approach this as I have used this in the past.
House Painting and Roof Cleaning by Sutton provides
House Painting Services in Berks county PA
for all Interior and Exterior Projects
484-334-3999
4thGeneration is offline
The Following User Says Thank You to 4thGeneration For This Useful Post:
genecarp (10-31-2009)
Old 10-31-2009, 10:58 AM   #3
Re: Painting
Thanks for the Forever Door painting info. Will be painting it this week.
Tags
interior painting company, painters in reading pa
Painting 60 yr old red wood> Will it hold up? RoSSco Painting & Finish Work 6 08-13-2011 10:01 AM
Painting business start-up questions oneelwayfan_com Painting & Finish Work 56 02-02-2010 01:55 AM
florida painting license? desert eagle Contractor Licensing 3 07-24-2009 08:49 AM
Painting and handyman, should I simplify? englishdave Business 9 04-14-2009 07:19 PM
painting over enamel stripes mfrancis Painting & Finish Work 2 11-17-2008 10:30 AM
