Painters Tips
Old 12-20-2006, 11:27 AM   #1
Teetorbilt's Avatar
Painters Tips
Where did this thread go? I can't seem to find it.
Albert Einstein
Teetorbilt is online now
Old 12-20-2006, 11:48 AM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Painters Tips
Well, I found this one.
And this one.
ProWallGuy is offline
Old 12-20-2006, 11:56 AM   #3
Teetorbilt's Avatar
Re: Painters Tips
Thanks but neither was the right one.
There was a good tip about keeping the weather stripping from sticking when painting exterior doors. The weather is nice, I'll just pull the w/s.
Albert Einstein
Old 12-20-2006, 12:58 PM   #4
rws's Avatar
Trade: paint contractor
Send a message via AIM to rws
Re: Painters Tips
baby powder
rws is offline
Old 12-20-2006, 01:32 PM   #5
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Painters Tips
Originally Posted by rws View Post
baby powder
It's in my van, right next to the tampons
Signature Quote
slickshift is offline
Old 12-20-2006, 01:59 PM   #6
rws's Avatar
Re: Painters Tips
rws is offline
Old 12-20-2006, 02:44 PM   #7
LennyV-NHSNOLA's Avatar
Trade: Residential Renovations/Remodeling
Re: Painters Tips
How does the baby powder get applied to the weather stripping? Seems like vaseline would work better.
LennyV-NHSNOLA is offline
Old 12-20-2006, 02:46 PM   #8
ProWallGuy's Avatar
Re: Painters Tips
Slick applies it with one of these:
Old 12-20-2006, 03:07 PM   #9
Re: Painters Tips
Old 12-20-2006, 04:57 PM   #10
ProWallGuy's Avatar
Re: Painters Tips
BTW, I usually hit the weather stripping with a bit of this:
Old 12-20-2006, 05:19 PM   #11
Re: Painters Tips
Right. Chap Stick is made with petroleum jelly, same as vaseline, which is why I was thinking vaseline. I still want to know if the baby powder is a legitimate tip or maybe just a joke. I know we have a few class clowns out here. If baby powder is actually used, how is it applied and how does it keep paint from sticking to the w/s. It seems the BP would just be absorbed into the wet paint or dry on top leaving an unsightly finish.
Old 12-20-2006, 05:31 PM   #12
painterman's Avatar
Trade: Historic Restorations
Re: Painters Tips
Baby Powder...its the real deal. I have been doing it that way for years. Just puff it on right from the container. A little messy...but smells great Apply directly to the WS works great.
If you think that you have a damp area to paint let the power sit on that spot over night and it will draw the moisture out.
Stan
painterman is offline
Old 12-20-2006, 05:47 PM   #13
Re: Painters Tips
So... do you squirt the BP on the paint or WS? Does it matter what kind of WS... tubing or felt or metal or ???
Old 12-20-2006, 07:15 PM   #14
ProWallGuy's Avatar
Re: Painters Tips
Nothing is going to work if you close the door when its wet. Always keep the door cracked as long as possible before you shut it. I've seen guys use and artist-type brush (1/2" or so) and brush the powder on the weather stripping. These tactics are for the rubber weather stripping. I've never had a problem with felt sticking to fresh paint.
BTW, the phenomenon we are talking about is called blocking.
Stolen from the SW website:
Blocking
DESCRIPTION
Undesirable adhesion between two painted surfaces or between paint and weather stripping. The paint sticks to itself or to the weather stripping when a window or door is opened and usually leaves bare patches of substrate.
POSSIBLE CAUSE
• Not allowing sufficient time for the coating to dry before closing doors or windows.
• Use of a paint with low block resistance (e.g. when two painted surfaces touch, the paint tends to adhere to itself).
SOLUTION
See Lead Information.
Paint with an oil-base coating or use a high quality semi-gloss or gloss latex with good block resistance.
Remove all loose paint by scraping or other methods, and sand the surface to smooth out any rough edges. Remove all surface contamination by washing with ProClean Professional® Prep Wash Concentrated Cleaner or other appropriate cleaner; rinse thoroughly and allow to dry. Glossy surfaces should be sanded dull.
Prime as needed and topcoat. Follow paint label instructions regarding dry times.
Application of talcum powder, wax, or soap may temporarily relieve blocking.
Old 12-20-2006, 07:19 PM   #15
My custom title
Brushslingers's Avatar
Re: Painters Tips
Heh, I was gonna say joy... that's what I use.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 12-20-2006, 07:26 PM   #16
ProWallGuy's Avatar
Re: Painters Tips
Here's a totally unrelated tip for ya all:
Every time you finish off a 5 of paint or whatever, pull out the rubber seal from inside the edge of the lid, and wipe it clean. These come in handy quite often. It is the perfect sized rubber band. When you are done painting for the day, just dip your roller/screen in the 5 you are working out of, and throw some plastic over the top. Take the big ass rubber band, and snap it around the edge. This will keep a set up fresh for days.
Thank me later, OK?
Old 12-20-2006, 10:11 PM   #17
quality app's Avatar
Re: Painters Tips
I remove the w/s for a day or two until the door cures enough not to stick. although os softer paints will stick for weeks and need a lube.
quality app is offline
tips on painting baseboards with carpet floor and a tip for new painters Zeebo Painting & Finish Work 10 04-22-2011 06:42 PM
Hiring Painters!! shermanpainting Help Wanted or Looking For Work 3 02-13-2008 01:12 PM
Painters wear boots and you gotta believe me slickshift Painting & Finish Work 29 12-21-2007 08:09 PM
tips on technique and fixing cracks in wall 72chevy4x4 Drywall 12 02-28-2007 03:53 PM
Painter's Associations slickshift Painting & Finish Work 32 02-11-2006 08:12 PM
