Painted Graphic On Natural Wood?
Old 02-12-2018, 09:07 PM   #21
Southbluff's Avatar
Rewards Points: 68
Re: Painted Graphic On Natural Wood?
If you do not need the grain on the painted areas, I would seal the entire surface first. Then mask off the tinted area. Shoot the tinted area, remove mask, seal again, scuff sand, finish, scuff sand, finish, repeat finish and scuff sanding until the lip is not noticeable.
If you want the cleanest lines, and time is not an issue, after masking, spray the sealer lightly again, then shoot the color. I have not actually done this, but have read about the same technique for painting crisp edges.
Southbluff is offline
The Following User Says Thank You to Southbluff For This Useful Post:
DaVinciRemodel (02-12-2018)
Old 02-13-2018, 07:16 AM   #22
hdavis's Avatar
Rewards Points: 9,091
I'd be tempted to find someone who has an ink jet printer that would do it.
hdavis is online now
Old 02-13-2018, 07:27 AM   #23
rrk's Avatar
Rewards Points: 1,902
My refinisher does it this way-
seals top
light sand
mask
paint with laq
seals
sands
several clear coats
wet sand
2 more clear
wet sands to gloss
polishes to super high gloss
just like piano refinishing
rrk is offline
DaVinciRemodel (02-13-2018)
Old 02-13-2018, 07:59 AM   #24
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 782
Originally Posted by KAP View Post
That type of graphic, you might be better off with a vinyl stencil...
I'm guessing you guys are taking the example I posted to seriously. Our design is pretty simple - more like simple pinstriping.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
The Following 2 Users Say Thank You to DaVinciRemodel For This Useful Post:
hdavis (02-13-2018), KAP (02-16-2018)
Old 02-13-2018, 09:22 AM   #25
rrk's Avatar
That is what my refinishers do on pianos with gold pin striping. Lady who sands is from Honduras, all she does is sand, but she does it evenly and never sands through color. I would hate that job.
rrk is offline
DaVinciRemodel (02-16-2018)
Old 02-13-2018, 12:05 PM   #26
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
I like doing inlays. I just did some cool turquoise and coral stone for a bar top. I made some furniture with it as well. But it's pricey (crushed stone and epoxy resin $$$) and labor. They have black stone as well.
I buy my materials from Treeline. In fact I've got another one lined up fro an HO, just purchased a big chunk of pine slab from a sawmill which needs to be sanded down then inlayed in turq. Fun projects for sure.
Maybe your HO would be interested in going this route. You could lay out their design, fill with stone then epoxy over it for a nice hard glassy finish, Router out a design and just fill.
I buy my stone and glue from here
https://www.treelineusa.com/inlay-materials
kirkdc is offline
The Following User Says Thank You to kirkdc For This Useful Post:
Old 02-13-2018, 12:28 PM   #27
kirkdc's Avatar
Don't want to hi-jack..but I've done some of these in the past. Out here in CO and AZ this inlay work is pretty popular. I like the guys simple homemade jig to plane the slab.
kirkdc is offline
Old 02-13-2018, 09:05 PM   #28
r a s's Avatar
Trade: division twelve
Rewards Points: 1,088
For more details on that particular piece...
r a s is offline
The Following User Says Thank You to r a s For This Useful Post:
Old 02-16-2018, 08:15 AM   #29
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Originally Posted by DaVinciRemodel View Post
That's what I'll do! Got to be a way to do this. How do the guys in the automotive industry do it?
Graphics are typically clear coated. The graphics are sprayed if not vinyl so very thin. I think you need to clear it first to get good adhesion for the masking and then top coated. Also keeps it from soaking in to the wood, which it would.
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
Best wood for painted cabinets? mattsk8 Finish Carpentry 34 06-30-2016 10:24 AM
wood burning fire and pizza oven westmeath m Masonry 19 04-18-2013 08:29 PM
wood supplier looking for a an overseas resort partner project developer harrymontana Help Wanted or Looking For Work 1 02-16-2013 08:04 PM
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 12:34 PM
Natural Stone Veneer over Painted CINDER Block Tommy C Masonry 14 04-22-2009 11:46 AM
