Painted Graphic On Natural Wood?
Old 02-12-2018, 08:23 PM   #1
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 480
I have a customer that wants me to build a piece of furniture for them. The piece will have a graphic painted onto wood while keeping the area outside the graphic natural wood.
How would you go about painting the graphic without creating a “lip” where it was taped off?
I found this example of what appears to be a painted graphic on wood.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 02-12-2018, 08:26 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,134
Re: Painted Graphic On Natural Wood?
Apply the paint, and then clear-coat the whole thing?
Tinstaafl is online now
Old 02-12-2018, 08:27 PM   #3
Rewards Points: 480
I think that will still leave a lip... No?
Old 02-12-2018, 08:31 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Well yeah, but at least it would be "gentle". There really isn't any way you can have zero lip unless you route the wood a few thousandths lower in the area to be painted.
Old 02-12-2018, 08:33 PM   #5
Rewards Points: 480
That's what I'll do! Got to be a way to do this. How do the guys in the automotive industry do it?
Old 02-12-2018, 08:36 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Not a clue. I turn cars on and steer them.
Hey, just do an upsell. Make it an exotic wood inlay.
DaVinciRemodel (02-12-2018)
Old 02-12-2018, 08:38 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Airbrush.
Old 02-12-2018, 08:39 PM   #8
Rewards Points: 480
Airbrush.
I still think to get a solid paint color, it would take several coats = lip.
Old 02-12-2018, 08:43 PM   #9
tjbnwi's Avatar
Rewards Points: 1,744
Shoot the graphic, clear coat, after 3 or 4 coats sand flat, apply a topcoat. Thats how car guys do it....
tjbnwi is online now
rrk (02-13-2018), Tinstaafl (02-12-2018)
Old 02-12-2018, 08:48 PM   #10
KAP's Avatar
Trade: Custom
Rewards Points: 24,354
For something like that, you might be better off with a sprayed dye...
KAP is offline
Old 02-12-2018, 08:52 PM   #11
Rewards Points: 480
That sounds like a lot of work... you know I hate sanding
I 'll give it a try.
Old 02-12-2018, 08:55 PM   #12
Rewards Points: 480
I would like to dye it. But it seems like the dye would creep under the tape once it got into the wood grain. Is it possible to seal out the dye?
Old 02-12-2018, 08:58 PM   #13
tjbnwi's Avatar
ETS 125....or wet sand with 320...
Old 02-12-2018, 08:59 PM   #14
tjbnwi's Avatar
You'd have to shoot the dye dry and built it to the depth of color you want.
Old 02-12-2018, 09:02 PM   #15
Rewards Points: 480
"dye dry"? Say that 5 times fast.
WTH is dry dye?
Old 02-12-2018, 09:10 PM   #16
tjbnwi's Avatar
WTH is dry dye?
Shoot the dye from a distance so it is fairly dry when it hits the wood. This will decrease the chance of creep.
Use DNA for the carrier instead of water. Build the color, let it dry about 5 minutes between coats.
Think of it as toning, you tone from 18"-24" from the surface being toned.
DaVinciRemodel (02-12-2018), KAP (02-12-2018)
Old 02-12-2018, 09:13 PM   #17
Rewards Points: 480
Last question, I have been to several auto places here looking for pinstriping tape 1/16 – 1/8. They look at me like I’m nuts. Is there a place to order online?
Old 02-12-2018, 09:31 PM   #18
tjbnwi's Avatar
You can get tear away Fine Line or Single width 233.
http://www.tcpglobal.com/MMM-6314.ht...E#.WoJNUWaZPUo
https://www.rshughes.com/p/3M-Scotch...180213022642:s
Old 02-12-2018, 09:33 PM   #19
tjbnwi's Avatar
Practice using a #11 Xacto knife blade to set the tape in place. Use the blade in the handle as an extension of your fingers.
Tweezers help also.
Old 02-12-2018, 09:34 PM   #20
KAP's Avatar
Trade: Custom
That type of graphic, you might be better off with a vinyl stencil...
KAP is offline
Best wood for painted cabinets? mattsk8 Finish Carpentry 34 06-30-2016 11:24 AM
wood burning fire and pizza oven westmeath m Masonry 19 04-18-2013 09:29 PM
wood supplier looking for a an overseas resort partner project developer harrymontana Help Wanted or Looking For Work 1 02-16-2013 09:04 PM
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 01:34 PM
Natural Stone Veneer over Painted CINDER Block Tommy C Masonry 14 04-22-2009 12:46 PM
