Paint Touch Ups
Old 11-10-2005, 02:59 PM   #1
AHS's Avatar
Trade: roofing & Painting
Paint Touch Ups
My last 2 exterior painting jobs i've had a problem with the my touch up's not matching the same color that was painted the day before. It seems like the color is drying a little lighter & really sticks out. This is my first year doing a lot of exterior painting & I've never had a problem up until now. The weather is colder now & I'm done painting out side for the year but I'm wondering if the cold causes the paint to dry a differnt color or what. It seems weird that it's never happened & then it happened 2 jobs in a row
AHS is offline
Old 11-10-2005, 03:14 PM   #2
copusbuilder's Avatar
Trade: Builder/Remodeler- Master Electrician
Re: Paint Touch Ups
I have noticed darker colors can have more of a problem with that. Are you spraying and then touching up with a brush? Can you roll or feather it out with a brush?? Good luck!
copusbuilder is offline
Old 11-10-2005, 03:25 PM   #3
AHS's Avatar
Re: Paint Touch Ups
Ya, I spray & then touch up with a brush. I tried feathering the touch up's in with a brush but it still sticks out.
AHS is offline
Old 11-10-2005, 04:18 PM   #4
Dripless
Dale's Avatar
Trade: Painting and exterior wood care
Re: Paint Touch Ups
I think the pigment lays down different when its sprayed as opposed to brush/roll. Thats part of the reason it might be a good idea to backroll over a spray..it touches up better.
Dale is offline
Old 11-10-2005, 05:16 PM   #5
Re: Paint Touch Ups
Can you go back and re-spray the areas?
Old 11-10-2005, 05:25 PM   #6
dwbrooks's Avatar
Re: Paint Touch Ups
The last exterior I sprayed there were a few spots that needed touch up. I thought hitting the spots lightly with the sprayer would be the best plan, since that was the original appication method and you can feather easily with spray.
To my suprise you could clearly see the spots that I touched up with the sprayer . I went back with brush and lighty feathered it out with the brush almost dry toward the edges of the spot I needed to fix. It blended very nice and you cant tell at all.
This might not be much of a help to you, but want I'm saying is I've always had the best luck touching up with a brush. I use very minumal paint on the brush and feather it out very carefully.
dwbrooks is offline
Old 11-11-2005, 01:45 PM   #7
AHS's Avatar
Re: Paint Touch Ups
If you have 10 gallons of the same color paint 5 gallons were from 1 Sherwin Williams & 5 from another. Should the colors still match up. I know Roofing shingles have to be bought from the same batch otherwise the color will be slightly different
AHS is offline
Old 11-11-2005, 02:52 PM   #8
Re: Paint Touch Ups
My experience has been "probably not". We have run into that with different stores. We have even had problems with a 5 and 3 ones if we don't mix them all together.
Old 11-12-2005, 02:20 AM   #9
I'm just stirring the:
CGofMP's Avatar
Trade: .
Re: Paint Touch Ups
I am anything BUT a painter... so this may be totally off the mark.
First the spraying o VS brushing to fix problem sounds right on to me. I have had some minor experience with this with interior doors.
Another thought to ponder: Even in the same dye lot or when mixed by the same guy at the paint store colors will vary if ever so very slightly. I do not remember where I picked up the following idea, but it might be someting to consider.
Bracketing:
When you are painting use up 2/3 of the first container of paint and then mix in 1/3 + of the next container into the first, keep doing this as you go. This will help to blend the slight color variations.
When you get to the final container blend it all with the last one as best you can. Keep this for touch ups.
Memorable Places - My little home on the web
Member of the White Knights Of Contractor Talk
CGofMP is offline
Old 11-12-2005, 08:48 PM   #10
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Re: Paint Touch Ups
Instead of bracketing, we call it "boxing" your paint together. We usually get two or three clean 5 gallon buckets and mix it all at once filling each bucket half and half. We put our strainers into each of the mixing buckets and strain it clean as we mix it.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 07:59 AM
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 08:50 PM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
