Paint Stained Wood
Old 03-04-2007, 03:53 PM   #1
Tejano
jmthouston's Avatar
Question
Paint Stained Wood
jamb and doors need painting
and stain is glossy. I want to sand clean then prime but can i just bonding primer.
xim and Preprite bond say may adhere to glossy surfaces
would y'all use it?
or what would y'all do to not sand.
jmt
jmthouston is offline
Old 03-04-2007, 04:06 PM   #2
My custom title
Brushslingers's Avatar
Re: Paint Stained Wood
Id use an alcohol primer and sand... takes ALOT of work away from running over old glossed wood.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 03-04-2007, 04:36 PM   #3
DeanV's Avatar
Trade: Painter
I would sand and hit it with something like coverstain. I love BIN, but it burns through edges when you sand it since it does not build thick and I wonder if it is more prone to chipping than a more flexible primer.
DeanV is offline
Old 03-04-2007, 04:37 PM   #4
Joewho's Avatar
Trade: Painter
That's not a whole lot of sanding. You only need to sand enough to dull the glossy surface for an excellent bond.
If you want to do it without sanding, xim and preprite will do as good as any bonding primer, but for the little effort of sanding, you get a much better job.
Joewho is offline
Old 03-04-2007, 04:43 PM   #5
...jammin
slickshift's Avatar
Trade: Rock Disciple
would y'all use it?
Light/scuff sanding
Solvent-based primer
Zinsser's Cover Stain
Or if it's dark stained wood, Zinsser's B-I-N
Signature Quote
slickshift is offline
Old 03-04-2007, 04:44 PM   #6
...jammin
slickshift's Avatar
Originally Posted by DeanV View Post
...I love BIN...I wonder if it is more prone to chipping than a more flexible primer.
Not an issue
Signature Quote
Old 03-04-2007, 06:58 PM   #7
gary lee's Avatar
Trade: painting contractor
I am a creature of habit, so I always scuff the surface a little. Prime with xim or coverstain. Would any of you have faith in the latex bonding primers holding up/doing the job in this situation?
Gary
gary lee is offline
Old 03-04-2007, 07:12 PM   #8
Tejano
jmthouston's Avatar
Smile
thanks all
going with a lite sand and preprite
Never used alcohol primer. Who manufactures it? Better than a bonding primer?
slickshift Quote:
would y'all use it?
Light/scuff sanding
it is dark wood.
why do u recommend zinsser's BIN?
Would it take coat away?
jmt AGAPE
Old 03-04-2007, 07:52 PM   #9
...jammin
slickshift's Avatar
it is dark wood.
Not sure what coat away is
The BIN, it's a better stain blocker, and frankly it has unbelievable adhesion
I'd recommend it for any time going over stain really
But the truth is it's stinky, you need fresh air and a respirator
And doesn't apply real well (it's watery), and being shellac, you might as well use a throw away brush to apply it
The oil-based will usually work OK
But the BIN is a better stain blocker
So on something lighter colored, I might use Z's Cover Stain
If it's darker. I'll use Z's BIN for sure
Signature Quote
Old 03-04-2007, 07:54 PM   #10
...jammin
slickshift's Avatar
Not really
But I haven't used a lot of latex primers in this situation
The creature of habit thing....
Signature Quote
Old 03-04-2007, 08:33 PM   #11
Tejano
jmthouston's Avatar
to take a coat away
I would use two coats on lighter wood color and since u stated another product for darker wood I may have to use three.
that is if I don't use Z's BIN.
Old 03-04-2007, 10:37 PM   #12
MakDeco's Avatar
Trade: Painting Contractor
Gary
I have had some sucess with Z's 123 before if smell was an issue with HO's but Bin or Cover Stain are great for that purpose.
MAK Deco
MakDeco is offline
Old 03-05-2007, 07:57 AM   #13
My custom title
Your answer - Zinsser's B-I-N
Benn
Old 03-05-2007, 02:10 PM   #14
DeanV's Avatar
Trade: Painter
As far as the waterbase primers, I have found then will adhere fine if you sand properly, but sometimes there will be bleed through, even from wood such as light oak.
DeanV is offline
Old 03-05-2007, 05:19 PM   #15
Pro Painter
AAPaint's Avatar
I agree....BIN it is. Sometimes we will use pro-block or the 123 if we have homeowners/children present during the painting indoors, but even then, we end up following up with a solvent based primer to lock out bleed through.
Anything water based takes the chance of liquifying the stain and/or wood tannins and bleeding through.
For things in this condition (already stained/poly'd) we always sand good, tack, prime, sand lightly (220 grit), tack, and two finish coats.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 07:59 AM
Lead base paint removal wood house. welovepainting Painting & Finish Work Picture Post 10 08-25-2007 03:31 AM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
