01-28-2009, 01:44 PM
#1
member
Trade:
Siding, windows, Aluminum crown
Paint or stain on hardi plank?
Hi guys, I am a siding contractor trying to decide whether to stain or paint the hardi plank on my own shop. I know paint would last longer but in the long run would prep work to re-paint (which I assume is much more work than prep work to re-stain) gradually out weigh the benefit of having to re-do paint finish less often?
I much prefer the look of stain over paint but I dont want to make the wrong choice and create a maintenance issue that I will probably have to live with for a long time.
Any feedback much appreciated!
01-28-2009, 03:45 PM
#2
Trade:
Painting Contractor
Paint it with Duration Satin two coats and you will have a great finish for about the next 15 years. Hardie will not peel. Stain will not work....plain and simple
01-28-2009, 03:55 PM
#3
Trade:
painting
I agree with SW Duration, to be honest I didnt know that you could stain Hardi board, never seen it done. But there is not much staining around here.
01-28-2009, 06:01 PM
#4
Trade:
Hardie can't be stained.
01-29-2009, 10:31 AM
#5
member
Trade:
Actually hardi can be stained. In fact it is offered as an option by hardi in their pre finished product line. The scary thing is they only warranty the pre stained material 7 years as opposed to 25yrs. for pre painted.
The pre stained material really has a nice deep woodgrain look.
01-29-2009, 11:41 AM
#6
Trade:
siding
hardi can be stained lot like doing a fiberglass door i would guess.The duration is an excellent suggestion also i think it has a lifetime warranty for what that's worth
01-29-2009, 11:43 AM
#7
Trade:
General, Electrical, and Plumbing Contractor
If by stain, you mean a transparant cedar stained look. then yes it can.
This is what we use.
http://www.superdeck.com/masonsselect/6700spec.htm
The Following User Says Thank You to Kgmz For This Useful Post:
01-29-2009, 11:46 AM
#8
Trade:
siding
paint would be easier to touch up around a shop i would think
01-29-2009, 01:06 PM
#9
Trade:
Painting Contractor
Paint it, like Premier said
You need to apply 2 coats for warranty as well.
01-29-2009, 02:19 PM
#10
member
Trade:
Thanks KGMZ for that link.
Have you seen good results with that type of finish? Every body paints the hardi around here so I havent been able to look at a job that is more than two years old.
At two years it does look great still, I wonder about after five or ten.
Am I correct in assuming that re staining would be easier than re painting labor wise?
Thanks to all
01-29-2009, 03:34 PM
#11
Trade:
Painting/Framing/Drywall/Tile
I have never seen any paint that has lasted a lifetime, so don't buy duration for that fact alone (easy for manufacturer to back out of warranty) I would go with an elastomeric paint that is suited for concrete/brick/masonry substrates.
01-29-2009, 04:05 PM
#12
Trade:
siding
i was just stating the warranty, wasn't assuming anything.The hardi is a very stable product and duration is way flexible enough
01-29-2009, 05:02 PM
#13
Trade:
 I wasn't trying to be a jerk.. was more saying don't buy it for their "warranty" cause like anyone they can weasel out of it
The Following User Says Thank You to nEighter For This Useful Post:
01-29-2009, 05:32 PM
#14
little fish
Trade:
general contractor
hardi recomends a solid color stain
01-29-2009, 05:41 PM
#15
Confidence of Quality
Trade:
Framer/siding/metal roofing/remodeling
If you google james hardie siding they have some pretty specific instructions on applications and coverings and they do state that it should only be painted not stained
The Following User Says Thank You to jdframer For This Useful Post:
01-30-2009, 06:29 PM
#16
little fish
Trade:
general contractor
if that is so (i'll check in to it) then they changed somthing. we have been staining hardi for the last 7 years... when we first saw the product i looked into the manf. specs and it stated premium solid color stain.
01-30-2009, 06:40 PM
#17
little fish
Trade:
general contractor
well it does say no stain... but i can only interpret that as wood stain and not as an acrylic solid color stain. maybe they found it's been failing? i gotta call my rep on monday and get to the bottom of this.
01-30-2009, 07:00 PM
#18
Trade:
That's what I originally stated. You have to go with the manufacturer on these issues, not what "can" be done.
The Following User Says Thank You to precisionbuild For This Useful Post:
01-31-2009, 06:58 AM
#19
Sarcastic Prick
Trade:
Paint and Floor Covering Retailer
The last time I reads specs on the product it stated Acrylic paint or Acrylic solid stain. No oils, and no mention of s/t stains. That was a couple of years ago so they may have changed it. I can't see why an acrylic solid stain would have any issues at all. Sikkens RSF is made for such applications. In some cases I'd rather trust a reputable coatings company like Sikkens that makes a product to handle this situation, than the manufacturer of the siding that can't possibly take into consideration all the coatings out there that may be applied to the siding.
01-31-2009, 12:55 PM
#20
Trade:
siding
well you can get it prestained wood look so the must be some way of doing it
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
