Trade: Finish Carpenter
Paint Or Stain On Cedar?
This is my first post.
I am a finish carpenter in Fargo, ND. I am preparing to re-paint the family lake cabin. It is about 1,000 square feet on 60 year old cedar that hasn't been painted in 10+ years. I would appreciate input on the following from an experienced tradesman. 1. Paint vs Stain? 2. Latex vs Oil? 3. Roll vs Spray? 4. Any particular brand? The planned prep work is pressure wash with 100 grit random orbital following. The windows are getting covered with coil stock after paint. The color is yellow. |
Trade: hack painting
Re: Paint Or Stain On Cedar?
If its already been painted...I'd stick w/that. Otherwise you'll need to strip it to bare wood for stain
Doer of Many Things!!!
Trade: Paint and Floor Covering Retailer
If you are going all the way back to the bare wood I'd stain it, either solid or semi-transparent depending on your taste. I'd use Sikkens Rubbol products. Oil would probably be best on cedar.
Trade: Exterior Surface Specialists
Take it back to bare wood - neutralize properly. Good oil based stain
![]() Celeste
Deck Cleaner
Trade: Deck Cleaning, Staining, Restoration
What Celeste said... Also, don't go above 60 grit paper
Trade: Painter
If it is down to bare wood, I would go with a first coat of BM ext. oil primer, the one designed for under acrylic stains, and then top coat with a good 100% acrylic stain. You will get better color retention from the acrylic vs. oil.
Deck Cleaner
If its down to bare wood, putting on a solid would be sacrilage (sp). Penetrating, oil based semi transparent stain/sealer is the way to go for easiest maintenance and once coat application.
#8 | |
...jammin
Trade: Rock Disciple
I'm assuming it's a solid colr you are going for
I'd use Sikkens Rubold oil-based solid stain All the old paint doesn't have to come off, just the loose/questionable bits amd sand it up nice Applicator depends on what the siding is Prolly brush though
Signature Quote Quote:
Trade: Wood Restoration/Refinishing
100 grit too fine. 50 or 60 grit
Charlie Soden Apex DeckSavers "New life for old wood" Deck cleaning and staining Wake County |
Sikken's specs 80 girt. Anything higher than that is too fine really. I've had a customer use Sikken's DEK Finish and actually try to sand between coats with 200 grit. Talk about a nightmare. I just couldn't get it through his head that it wasn't like finishing furniture.
| Should I use paint or stain for this exterior | Miniroller | Painting & Finish Work | 8 | 03-29-2010 12:29 PM |
| Concrete paint or stain? | cjc | Painting & Finish Work | 4 | 08-06-2007 10:12 PM |
| Cedar Railing Stain for the Pros | gregt848 | Painting & Finish Work | 6 | 09-28-2006 09:59 PM |
| How to get Paint off of a cement floor that has a stain finish | dfwhomeremodele | Painting & Finish Work | 8 | 03-06-2006 08:12 PM |
| French door paint and stain | Luke's Dad | Painting & Finish Work | 6 | 02-23-2006 09:57 AM |
