Paint Or Stain Board And Batten Siding?
Old 04-30-2011, 07:42 PM   #1
Improving Outdoor Living
Integritybd's Avatar
Trade: Outdoor Living and Remodeling
Rewards Points: 25
We're starting a siding job on a house where the customer wanted cedar board and batten. We gave them options and prices for architectural vinyl and hardie board, but they wanted natural products, so we're doing cedar. They also want it painted. My thought was that if it's painted, why not use hardie because it will last so much longer..
Anyway, it's a rustic mountain home on a mountain, should we stain or paint? Paint seems like a maintenance headache to me... But will stain last that long without needing to be reapplied?
Thanks for the input!!
Integritybd is offline
Old 04-30-2011, 08:00 PM   #2
Grumpy's Avatar
Rewards Points: 2,000
Re: Paint Or Stain Board And Batten Siding?
I'm not a painter. But I used to do alot of cedar siding. it has always been my understanding to NOT Paint cedar because the natural oils and esins will basically prevent a proper bond. Therefore you're left with the various stains as an option. Food for thought, the prefinish factotries will prefinish with primer and solid color stain and provide a 15 year color warranty.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 04-30-2011, 08:43 PM   #3
rock16's Avatar
Trade: Commercial Exteriors & Multi Family Remodel
Rewards Points: 274
Primer and a good latex and the finish will outlast stain by a wide margin. That said I like the look of a semi transparent stain much better.
rock16 is offline
Old 04-30-2011, 09:04 PM   #4
Bonzai's Avatar
Trade: Home Renovations & Repairs
Rewards Points: 252
So many homes around here with cedar siding ... Some naked, some stained, probably most painted. Do it right with a good quality primer and it will last a long time. It does soak up the primer like a sponge though
Renovations & Repairs. Bathrooms, decks, tile, paint & much more.
North Vancouver to Whistler and between.
TOLL FREE 1-877-804-3326
http://www.adventhomesolutions.com
Bonzai is offline
Old 04-30-2011, 09:14 PM   #5
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
A good stain is better but usually it is an oil, now I'm not sure haven't looked, still available?, oil primer is just as good as solid oil stain, but you can cover with a latex, the hot sun takes a toll on both, what sort of weather will it get?
Pete'sfeets is offline
Old 04-30-2011, 10:43 PM   #6
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
I think painting cedar should be a crime. I would stain it.
JHC is offline
Old 05-01-2011, 10:08 AM   #7
Rewards Points: 25
Its on lookout mountain ga so the temperature may get to the upper 90's. The area was actually hit by the tornados last Wednesday. The house is ok, but there isn't any shade on the house now. We do have some pretty cold winters too. Hope that's enough info.
I'm also really curious about the maintenance between the two. Staining seems like less maintenance, as repainting seems like such a hassle to strip the old paint etc. Reapplying stain seems so much easier. I also understand that some stains may bleach out in the sun, is that true of most stains even with some of the new uv inhibitors? Even still, that seems to give it a more natural look anyway.
Thanks for the replies so far
The Following User Says Thank You to Integritybd For This Useful Post:
Gregory D (01-02-2014)
Old 05-01-2011, 11:05 AM   #8
JHC's Avatar
Rewards Points: 516
This stain job is seven years old now. Six in this picture when I washed it last year. THe first pic side is in direct sun from 1 pm on till sunset. This home is in Surf City about 20 yards from the intercostal waterway.
This is SW woodscapes, a 100% acrylic product. Windows, door trim, doors, and handrails were done in Duration.
JHC is offline
Old 05-01-2011, 11:05 AM   #9
katoman's Avatar
Trade: carpenter
Cabot Stain. Make sure you do up a sample and get the HO to approve it before you go and buy a bunch of stain.
If you were to prime and paint, then by rights the back of the siding has to be at least primed, otherwise moisture will 'blow' the paint off.
I agree painting cedar should be a crime.
katoman is offline
Old 05-01-2011, 08:14 PM   #10
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
the most important factor in getting any finish to properly bond to any exterior wood is to not let it be exposed to uv prior to finish,enough damage to compromise the final coating can be done in as little as 1 week depending on exposure
install pre primed or prefinished
Tom Struble is offline
JHC (05-01-2011)
Old 05-01-2011, 09:07 PM   #11
Rewards Points: 25
Thanks for the pics! What about the pro's and con's of transparent, semitransparent, and opaque stains? Are there any semitransparent stains that may last as long?
Old 05-01-2011, 09:22 PM   #12
Rewards Points: 25
Also. I know that going from painting to staining would be a real pain, stripping to a point where a stain could be applied seems almost impossible. However painting over a stain seems like it shouldn't be such a big deal, is that true or would the stain cause the paint not to do well? Thanks again for all your help so far!
Old 05-02-2011, 12:17 AM   #13
JHC's Avatar
Rewards Points: 516
I would suggest you go to your local Ben Moore and talk to them about Arborcoat. Its a higher end product that SW woodscapes, but its worth it in terms of longevity imo.
Also yes to your second question. Painting over stain is easy, but you can also re-stain just like painting with these waterbornes without color blotching being an issue.
JHC is offline
Old 05-08-2011, 10:46 PM   #14
artiospainting's Avatar
Trade: painting and cleaning
Rewards Points: 250
What about your tannin bleed cedar need to sit for about 12 mouths to bleed other wise it will bleed throw the paint or stain. It could be longer then 12 mouths I get a lot of calls people complain of it on there new home. they painted it or stained it so they could git it done and the general could sine off everybody's payed one year latter bleed throw shows up. unhappy buyer. paint and stain keep on changing thy took the solvents out of stain i Liked stain better but now i dont know. paint stores bont seam to talk about there changes they'll just boast there's the best stains seam to be falling EPA made them all chaing
artiospainting is offline
Board & Batten replacement TheBentDude Windows, Siding and Doors 6 10-12-2010 12:14 AM
Board & Batten FC Siding jakejorgenson Windows, Siding and Doors 8 10-08-2010 04:10 PM
Hardie board siding question enforcer Windows, Siding and Doors 1 08-02-2010 09:03 AM
board and batten siding enforcer Windows, Siding and Doors 4 09-08-2008 06:12 PM
board and batten siding dutchlegacy Windows, Siding and Doors 8 03-21-2008 11:28 AM
