Paint Sprayers
Old 12-05-2008, 11:54 AM   #21
Workaholic's Avatar
Trade: Painting Contractor
Re: Paint Sprayers
I just run warm water through mine when avalible. I would not store with watr in your pump and lines. Rust will slowly eat away your pump. keep some paint thinner in your rig. Or you can use something like graco's pump armor. Or some diluted antifreeze. Storing in your garage is fine.
Sean
Workaholic is offline
The Following User Says Thank You to Workaholic For This Useful Post:
Brocktologist (01-12-2009)
Old 12-07-2008, 09:58 PM   #22
Custom Home Builder
BiggersJunior's Avatar
Trade: Residential Custom Builder
Re: Paint Sprayers
I know this is a dumb question for you pro's, but how much liquid will the lines and machine need to "winterize" the machine while it's not in use? And should I dilute paint thinner with water or just use straight paint thinner?
Another question...when painting with the machine, do you always have to use a 5 gallon bucket or can you use just a 1 gallon can of paint? I know it will go through it fast, but is there anything wrong with this scenario?
BiggersJunior is offline
Old 12-08-2008, 06:43 AM   #23
Al Truistic's Avatar
Re: Paint Sprayers
To answer your question, if you are running 50' of hose a half gallon will do it. But as I said before, don't let your machine freeze, hence don't let your hoses freeze, problem solved.
And yes, you can paint out of a single, and I occasionally do it especially when doing small jobs, or when I only need a few gallons of paint, you just have to top it off more frequently.
I know most would probably disagree with me but I keep both my machines in paint 24/7 365. And have been for almost 20 years. As long as you use the machines regularly (at least once a week) they will be fine. Rust isn't a problem, because there is no air in a closed system. The only time I have had a problem is when the machine sits too long, and I am talking week, and the paint "settles" and solids form.
I may be in different situation than most though, because I alternate between 2 machines and basically use the same colors in each machine, and I use both of them each week.
Just my 2 cents.
Al
Al Truistic is offline
Old 01-12-2009, 01:00 AM   #24
dejure's Avatar
Trade: finish carpentry
Re: Paint Sprayers
Even stainless steel can rust, believe it or not. If you have to let your airless set for any time at all, run a mixture of oil (even motor oil will work) thinned down with paint thinner and some alcohol (alcohol mixes with water and oil). You can even put a few table spoons of lacquer thinner in it to dissolve old paint. The oil will help protect your metal parts.
dejure is offline
Old 01-12-2009, 05:34 PM   #25
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
Re: Paint Sprayers
for storage between uses, i always leave thinner in the machine and line and have never had any issues. some guys even use anti-freeze but i have never tried that. i know a guy that uses windshield washer fluid and swears by it.
vandyandsons is offline
Old 01-12-2009, 05:48 PM   #26
A bit abrasive.
WisePainter's Avatar
Re: Paint Sprayers
I gotta go with spirits too.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 01-12-2009, 08:33 PM   #27
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Re: Paint Sprayers
I put in RV Antifreeze into my lil' 390 about a month ago and I plan to take apart the pump before I use it to see how it looks and will post back soon with my findings.
Brocktologist is offline
Old 01-12-2009, 09:49 PM   #28
Workaholic's Avatar
Re: Paint Sprayers
Graco's pump armor is watered down antifreeze
Sean
Aura Paint Review (Matte Finish) DeanV Painting & Finish Work 43 05-06-2010 09:45 PM
Paint Sprayers Clev Contractor Painting & Finish Work 7 07-14-2008 11:31 PM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
