Paint Process For An Existing Home
Old 12-07-2008, 10:21 PM   #1
Custom Home Builder
BiggersJunior's Avatar
Trade: Residential Custom Builder
I just bought a Graco 495 and want to figure out the most organized, simple process in painting the interior of an existing home with as little trail and error as possible.
For example, let's say the house is 1,400sf, 3 bedrooms, 2.5 baths, with carpet and vinyl flooring. The flooring will not be removed. The house has baseboard trim but no crown. The ceilings do NOT have popcorn and will be painted white. The walls will be beige.
How do you cover the flooring and with what material? How do you cover the walls or ceiling? And what order do you paint each part of the home? I know these are entry level questions, but you guys have all of the experience which can help us save time. I look forward to your comments.
BiggersJunior is offline
Old 12-07-2008, 10:29 PM   #2
Deck Designer/Builder
DecksEtc's Avatar
Re: Paint Process For An Existing Home
I'm not a painter (even though I've painted more houses than I care to count) but I'd cover the floors with tarps, paint the ceilings first, paint the trim/doors second and the walls last.
DecksEtc is offline
Old 12-07-2008, 10:39 PM   #3
Sean
SLSTech's Avatar
But he has a spray gun & that would be a lot of taping
Ditto with the floors
Ceiling - walls using a painters shield - trim with a brush
doors sprayed outside
Better yet - hire it out unless I can spray everything at once the same color - that's my system
SLSTech is offline
Old 12-08-2008, 12:05 AM   #4
Workaholic's Avatar
Trade: Painting Contractor
Sean
Workaholic is offline
Old 12-08-2008, 01:06 AM   #5
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Spray the ceiling and trim/doors .... roll the walls!!!
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
Old 12-08-2008, 08:35 AM   #6
RCPainting's Avatar
Trade: Painting in Utah
There are several ways to paint it, all one color/sheen or different for trim/walls/ceiling?
Is the house empty?
As far as carpet, run a 2" piece of tape along carpet at base, use a putty knife to push it down (between base and carpet). Then run a 12" paper, use a masker, along tape. You can then lay plastic if you want, tuck it under paper and tape to carpet. Put drops down over that. Now you will not "pull" on masked edge when you walk on drops.
You might want to go to painttalk.com and read up!
http://www.painttalk.com/f22/new-con...sequence-1165/
RCPainting is offline
Paint Sprayers BiggersJunior Painting & Finish Work 27 01-12-2009 09:49 PM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
Illinois Mechanics Lien Forms and Instructions Ed the Roofer Business 4 02-23-2008 08:58 PM
Home depot Crackle paint Miller Painting & Finish Work 7 09-18-2007 01:30 PM
Older Home NW Painter Painting & Finish Work 3 05-07-2007 10:58 PM
