Trade: general contractor
Paint Problem
Hi everyone
I am new here and am having a big problem I was hoping you can help me out with. I just finished a 3,000+ sqft home all new drywall and the owner bought all the paint for me to apply.She purchased sherwin William's pro block primer and a semi gloss almond for walls and ceiling. I told her we needed a pva but she wanted the pro block. Here is the problem, there are areas of the paint peeling off(but only when tape is applied and ripped off), mostly around the switch covers. Here is some more info, She was short a few gallons and I purchased some pva primer, those walls are not peeling at all and look great. I broomed all the walls and put one coat primer (coverd like a finish coat) and one coat of semi gloss almond. My question is "what did I do wrong? or is it the wrong primer? sorry for the long post but any help would be great thanks |
Side Effects May Vary
Trade: Professional Painting
Re: Paint Problem
You are putting tape on the walls? Why ?
1 coat of primer and 1 coat of finish with a semi? Why? |
Re: Paint Problem
Her way of telling me the paint is peeling(tape and rip off????). She owes me alot of money. Her idea to paint everything semi gloss.
A bit abrasive.
Re: Paint Problem
Sounds messy.
My advice: Hire a real painter to do it. |
Trade: Painting Contractor
Re: Paint Problem
Sounds terrible. Semi- on walls and ceilings? How long ago were the walls painted before applying tape?
Sean |
Re: Paint Problem
About 6 months
Trade: Designer/Contractor
Re: Paint Problem
hey prime----What's on the back side of the chip ??? Any dry wall dust ??
The tape test is a pretty agressive way to prove a point. A liitle duct tape and a good yank----hell any thing may come off. My paint rep. uses that to check adhesion. Have your S/W rep check the job and paint for you. good luck with your customer.. |
Trade: Historic Restorations
Re: Paint Problem
Lets see...you painted it 6 months ago...and you still have not been paid.
Trade: Painting in Utah
Re: Paint Problem
That is why painters don't warranty HO supplied paint, if they use it.
Need more details Exactly which problock? Was temperature/humidity normal? Primed and painted 6 months ago and now peeling? Has the house been occupied? You should be able to get your SW rep out there to help you. |
nick@nite
Re: Paint Problem
What is it with HO'S wanting to supply paint? we have gotten alot of that lately when going out on estimates..........
I hate it when they ask my advice about a paint problem ......and then when I give my humble expert advice..there comeback is well.......my mail man who paints said I should do this............
Re: Paint Problem
Thanks for all the replies. The reps were out a few weeks ago and took some samples for testing. My question is do you think the prep rite pro block bond/seal is good enough for new drywall? there website says it is for previous painted drywall and other various uses. They recommend the 400 or high build for new drywall. what do you all think.
Temp was dry and from what I remember around 65 outside. Southern california. The h/o says it has been peeling since The day we finished. The final walk through with her and nothing was said about it. I dont think she had the money to pay. |
Re: Paint Problem
I have applied the cheapest flat paint my old boss could find as primer and have never seen it peel. If you have interior paint peeling then my bet would be a moisture problem. But then again people are sticking tape on the wall and "ripping it off" so that wouldnt exactly be optimum conditions.
I always let the customer know that if they supply the paint that I will bid it by the coat and will offer no warranty at all. I write it all in the contract and will not start untill the contract is signed. Did you say you rolled on the paint or sprayed it? Shouldnt really matter, but just curious.
http://InDemandPainting.com http://www.SupermanOfPainting.com http://www.AplusPaintingServices.com Last edited by ModernStyle; 03-17-2009 at 07:55 AM. |
Trade: Painter, Stainer finishers Home constr. cleaning
Re: Paint Problem
Every time I have seen the paint peeling or cracking it most of the time has had to much moisture in the house or to cold..... And I think your right she most likely doesn't have the money. I do not let the H/O buy the the paint I use. I would rather get the paint myself and pass the discount on to them that I receive so that I use what I like and trust
A bit abrasive.
Re: Paint Problem
This still sounds messy.
Trade: Painting, flooring
Re: Paint Problem
Did the paint start peeling after you asked her to pay up?
Re: Paint Problem |
A bit abrasive.
Re: Paint ProblemMess recognized. Now you get to flap your "Diplomacy Wings". Fly high and far fearless one for your money is on the line. Get paid.
#18 | |
Trade: commercial building restoration
Re: Paint ProblemQuote:
Did you final coat the walls 30 days after you applied the primer? |
#19 | |
| can any owners of Paint Shaver Pro give me a review? | jordanski | Painting & Finish Work | 7 | 11-08-2009 05:59 PM |
| Ceiling Paint? | steve-in-kville | Painting & Finish Work | 38 | 04-09-2009 08:04 PM |
| Best Paint for the Conditions? | realpurty2 | Painting & Finish Work | 9 | 01-16-2008 08:02 PM |
| Possible Behr paint problem | Steve Richards | Painting & Finish Work | 35 | 11-29-2007 08:56 PM |
| Oil Based Paint leaving wrinkly finish on doors | dwbrooks | Painting & Finish Work | 8 | 11-09-2005 11:29 PM |
