Paint And Primer In One
Old 03-01-2012, 02:41 AM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
What are you guys thoughts on paint and primer in one. My view is I wiil use it one some new wood trim or maybe a small job, but if you had a house with all new drywall, would you trust it. Last couple jobs I did that involved painting, I primed with zinzer and then painted. Is doing it that way a waste with the new products that are out or do you guys think that they are inferior to using a primer, letting it dry and then painting?
bluebird5 is offline
Old 03-01-2012, 03:12 AM   #2
Reet
Spaint90's Avatar
Trade: Painting/ Sales
Rewards Points: 250
Re: Paint And Primer In One
There are some products out there that work pretty well as a paint and primer in one for drywall. I would not use these products over wood, or just for the sake of small jobs. I always prime anything new with specific primers.
My feeling is that to put the two together you are making compromises. I always use primer for primer, and paint for paint.
Spaint90 is offline
Old 03-01-2012, 05:38 AM   #3
manipulator of wood
I Mester's Avatar
Trade: general contractor
I agree. I think by trying to combine the two. something is compromised. always use primer. and then paint. but then you have people who swear by it and it works. soo.everyone has his quirks i guess.
I just love the smell of sawdust in the morning!
I Mester is offline
Old 03-01-2012, 06:43 AM   #4
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,160
I think they are more of a gimmick for the DIY crowd who don't know if they need to use a primer or not. If I need a primer then I use a primer that is specific to the job at hand.
Ohio painter is online now
Old 03-01-2012, 07:01 AM   #5
johnzenobia's Avatar
Trade: General
You want to prime first to have a nice flat white surface for the paint to adhere to and allow the real color of the paint to be shown. Paint and primer in one is for diy homeowners that don't know what they are doing.
Also paint manufacturers are just looking to raise the price somehow.
johnzenobia is offline
Old 03-01-2012, 07:14 AM   #6
Jackpine Savage's Avatar
Trade: General Contractor/carpenter
Rewards Points: 152
If it's going to take you more than one coat, what you are doing is using some very expensive primer.
Jackpine Savage is offline
The Following 3 Users Say Thank You to Jackpine Savage For This Useful Post:
jkfox624 (04-25-2012), KAP (03-23-2016), summithomeinc (03-04-2012)
Old 03-01-2012, 07:33 AM   #7
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
I actually saw a customer paint their basement reno with the stuff, could help but giggle, fifty bucks a can when primer is 15 plus. I can like a primer included to deal with and consider a few nail holes and patches. The Manufacturer's ought to have the common sense to become a little human and explain that the prime included is to improve against flashing , not replace primer. Proof that their tactics are tom foolery instead of integrity. Does the primer included completely remove flashing effects, I don't think so.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 03-01-2012, 04:09 PM   #8
Megabass's Avatar
Trade: Painter
As far as the nomenclature of "Paint and Primer in One", it is just that, a nomenclature. A more accurate description of the product in professional terms would be a self priming paint. These paints generally have better adhesion than their non self priming counterparts. Having said that, I have never found a real situation where using these products would stop me from using a primer where needed. In fact, the tag of "Paint and Primer in One" is geared toward the DIY'er in advertising.
I sell this stuff at my job all day long when I'm working. Customers ask for the paint with the primer in it as if it was actually paint with primer dumped in and mixed... I have to educate them and tell them it's a self priming paint, that it has about a 10-15% better opacity than a paint a step down, that the binders and resins are of a higher quality which promotes the following 2 things: better adhesion, and a much more durable finish. I actually explain to them that as professionals, the fact that it is self priming is the least thing we care about. I sell the products on the durability mostly. Yeah, they cover a little bit better, but usually not enough to warrant 1 coat where we would usually use 2 to get the job done.
I would never apply it on bare drywall. Where proper application to the mil specs and two coats would prevent flashing, it's just not a complete job. I still sell them drywall primer and tell em 2 coats over that for bare. If you can later do a color change in one coat AFTER a correct first painting, go for it. I have used it for myself over bare wood trim and it worked flawlessly in 2 coats. Of course, if there is any tannin, you need to shut that down first with a stainblocker.
Overall, I do like these paints, but not for the reasons the advertising tells people about them. I have used a lot of Valspar Signature with good success. At 31-34 bucks a gallon, it's a solid product. It's not SW duration, but it's not 50+ a can either. Some people will come back and say the paint sucks or it failed or some other idiot excuse. After a brief interview by me to them, I know they had a failed job simply because they have no idea how to paint. It usually isn't the coating. The only "issue" I have had with say Signature is that on SOME of the colors, I cut my cut pot with about 5% water to get it to flow better, but hey, with the reformulations of lots of the paint, pulling like a tank on the cut in is pretty common.
Megabass is offline
The Following 2 Users Say Thank You to Megabass For This Useful Post:
Munanbak (03-01-2012), tedanderson (03-19-2016)
Old 03-01-2012, 04:14 PM   #9
President of the world
world llc's Avatar
Rewards Points: 2,001
the title of this thread makes me laugh...
eventually, even painters are going to believe it is....
world llc is offline
Old 03-01-2012, 04:27 PM   #10
Thom
thom's Avatar
Rewards Points: 4,748
I've used it on drywall, it works fine as a primer, it works fine as paint. It will not cover in one coat. Put on three coats and it's great. Of course you could also put on a single primer and a double paint and get the same result.
thom is offline
The Following 2 Users Say Thank You to thom For This Useful Post:
jkfox624 (04-25-2012), tedanderson (03-19-2016)
Old 03-01-2012, 06:12 PM   #11
jimbo3636's Avatar
Trade: Painting contractor
It depends on what your finish is going to be. I have done many hotels, condo buildings, apartments ect....I use a primer finish for the walls and the ceilings, spraying and back rolling. Wood I don't believe there is a product, if so enlighten me. Hope this helps.
Chicago Painters
Commercial painters in Chicago
jimbo3636 is offline
The Following User Says Thank You to jimbo3636 For This Useful Post:
JHC (03-04-2012)
Old 03-04-2012, 05:26 PM   #12
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
It all depends on where you are applying it. Many of these new primer and paints in one work better than drywall primers. Several that are over $35 a gallon that work very well to seal mud and paper on gwb.
JHC is offline
Old 03-04-2012, 09:15 PM   #13
Miss Brown's Avatar
Trade: Wood n' concrete finishes
Rewards Points: 150
Aura. Works. On exterior wood. I'm not kidding. PT. 2 coats and it looks great. Three, even better. On my way to the poor house...as it cuts me out of labor for a primer coat. But I don't pay myself on my own house, and I have aura leftovers....good thing my favorite color is whatever all those jobs are when I mix them together. GREY.
More money than time= 80.00 a gal no problem.
Miss Brown is offline
Old 04-24-2012, 11:15 PM   #14
paint_grl_25's Avatar
Trade: Paint Store Rep.
Paint and primer in one is really just a sales gimmick. I would say about the only thing I would use a self priming paint on is new drywall; and that's only the case with Flat paints. Most interior flat paints are self priming on new drywall. A lot of painters will even use a very inexpensive paint as a primer for new drywall; before they top coat it with a higher grade paint (example would be priming the walls with a product like Dunn Edwards Superwall and then painting over with a higher quality product such as their SpartaWall or Suprema).
paint_grl_25 is offline
Old 04-24-2012, 11:35 PM   #15
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,832
I wonder how that interview would go?
The fact most self priming paints are junk. They take longer to dry. You are better off spending the $50 on good paint and priming the surface. But then again, I guess that I am an idiot and don't know how to paint.
TNTSERVICES is offline
Old 04-24-2012, 11:40 PM   #16
Reet
Spaint90's Avatar
Rewards Points: 250
Not to mention its cheaper to do it right..primers cheaper than paint.
Spaint90 is offline
The Following User Says Thank You to Spaint90 For This Useful Post:
TNTSERVICES (04-25-2012)
Old 04-25-2012, 12:08 AM   #17
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,067
And if possible, I like to get my primer tinted 70%ish the top coat color (color and product permitting).
Sir Mixalot is offline
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
Spaint90 (04-25-2012), TNTSERVICES (04-25-2012)
Old 04-28-2012, 01:50 PM   #18
MakDeco's Avatar
Trade: Painting Contractor
We have had times when it would be primer and two coats so two coats of primer and paint worked just fine on bare drywall, saved having to do the 3rd coat...
MAK Deco
MakDeco is offline
Old 02-29-2016, 03:58 PM   #19
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
I am a drywall finisher and like a high build level 5 as a primer...the two in one on new drywall I think is nuts and the price of Sherwin Williams paint and primer in one will cost 50 to 60 dollars a gallon that is insane. The last three jobs I have done DIY er s and one so called professional have used this paint and primer in one and not the 50 dollars a gallon kind please go on my icerock drywall page on Facebook and help me a little yout will see my post could yout add to it
icerock drywall is offline
Old 03-11-2016, 06:43 AM   #20
Pure Integrity's Avatar
Rewards Points: 38
I once inquired about this at a Ben Moore store and the clerk explained to me that the paint/primer in ones have a higher acrylic content, but it doesn't mean they don't require primer. He explained that over new drywall or wood, you still need a primer.
However, I have heard of a painter who uses this stuff exclusively. Now that I think about it, I'd like to try and avoid this painter.
Pure Integrity is offline
