Paint Over Solid Color Stain?
Old 10-13-2008, 03:57 PM   #1
MJM's Avatar
I have a customer who coated their house, which is T 1-11 siding, with Cabot O.V.T Solid Color Oil Stain about 10 years ago. Now the customer insist on having his house painted. Would I need to apply an oil primer before coating it with a water-based paint? I believe that the solid color oil stain in a sense acts as primer for paint, but I am not 100% sure so I just wanted to run in by some of you who may have had more experience with this issue.
MJM is offline
Old 10-13-2008, 04:42 PM   #2
General Contractor
Snow Man's Avatar
Trade: Construction Management
Re: Paint Over Solid Color Stain?
Pressure wash
prep
Water-based primer (tinted to color )
2 coats of finish .
just my own opinion
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 10-13-2008, 05:09 PM   #3
Spice's Avatar
Trade: General contractor
you should use an oil primer because if you don't the water based paint will peal off this is just from what I've seen in the past.
Spice is offline
Old 10-13-2008, 05:16 PM   #4
A bit abrasive.
WisePainter's Avatar
I recommend pressure washing, then applying a latex primer.
The wood has indeed been sealed by the oil based stain, so the wood will not require any further sealing.
However the latex top coat will need a proper substrate to bond onto, provided by the primer.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 10-13-2008, 05:17 PM   #5
General Contractor
Snow Man's Avatar
very wise
610 457-9721
Snow Man is offline
Old 10-13-2008, 11:41 PM   #6
Any Season's Avatar
It's already been said that the solid stain has sealed the wood there, and its not an issue to go over stain with paint, you just have to keep in mind that there is a sheen ladder (flat->matte->eggshell->satin->semi->gloss->higloss) and stain is flat. You can always go up the ladder but never back down. Ex. flat paint over semi gloss paint.
Any Season is offline
Old 10-15-2008, 05:32 PM   #7
John the estmtr's Avatar
Trade: Painting: Commercial, High Rise, Custom, Residential
+1 on what your saying, but I'd be careful here. He said it's an oil solid stain, and that could cause issues. If it was latex solid stain I'd say go for it.... Modern latexes are made to stick to latex.
Wash, sand and prep
Prime (find an ICI, use Gripper... one of the best primers that isn't Kilz or something)
2 coats finish
And if you have your paint store tint the primer, make sure they don't oversaturate it. Unless they're some of the new "deep base" primers, they probably shouldn't have more than 2oz of colorant per gal.
Experience: Formerly an outside sales rep for a paint manufacturer. Was offered a better job as an estimator for a paint contractor company and never looked back. So when I give my .02 cents, well it still doesn't matter...
John the estmtr is offline
Old 10-15-2008, 06:17 PM   #8
MJM's Avatar
Thanks for the input. I've checked with Cabot multiple times and each time they said no primer was needed for a latex paint topcoat. But I've also researched the issue and along with your inputs I am getting conflicting recommendations. To be ultra safe I think I will want to use a oil primer, but I hate working with oil primers on that large of a scale. Has anyone tried Zinnser's H2Oil-Base primer? It looks like a good alternative to traditional oil primers because it is low odor and cleans up with soap and water. If anyone has used this product, please tell me what you think.
Thanks in advance.
MJM is offline
Old 10-15-2008, 07:20 PM   #9
harness's Avatar
Trade: painter
i use cover stain all the time i tried the h20 it was ok but i still get better coverage with the oil and as far as low order well maybe outside a little but inside the h20 still stinks bad and i wear a mask i think it smells allmost as bad as oil and dries slower leaving the oder in the air longer
harness is offline
Old 10-15-2008, 07:59 PM   #10
A bit abrasive.
Wash, sand and prep
2 coats finish
Yes but the stain is 10 years old.
A special primer shouldn't be necessary now.
With the years of weathering a standard exterior latex primer and latex top coat will bond very well with just a pressure washing to remove the efflourescence (chalking/salt) left on the surface.
I would tint the primer as much as I could to bring it around to the final color but only to insure that 1 top coat will be necessary to disappear the original color.
Thoughts?
Old 10-15-2008, 08:02 PM   #11
A bit abrasive.
Thanks in advance.
A primer coat covers your butt.
Maybe not necessary by the manufacturers standards, but they aren't going to go to bat for you if anything happens.
Therefor a latex primer is the best bet.
Old 10-15-2008, 09:48 PM   #12
harness's Avatar
Trade: painter
i totaly agree with the wise painter wood being seald and any oil that was their is long gone and do think in this case a good latex primer tinted is what i would do
harness is offline
Old 10-15-2008, 09:58 PM   #13
Any Season's Avatar
Thanks in advance.
Cabot prescribes no primer for their stain bc Cabot Pro V.T is self priming. I also agree with Wise with regards to the oil stain weathering enough to accept latex stain with normal prep.
Aura Paint Review (Matte Finish) DeanV Painting & Finish Work 43 05-06-2010 09:45 PM
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 07:59 AM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
