Paint Over Eggshell
Old 05-31-2013, 08:30 AM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,725
Paint Over Eggshell
How do you paint pro's prep existing eggshell or satin for new paint? I did a condo and lightly scuffed the entire place, then "swiffered" everything with t-shirts. I'm wondering if that was even necessary if I had instead selected the right paint type/grade. In this case I was using Duron/SW UltraDeluxe (kind of low-end), but that's what the client selected.
I know painters that will paint right over those walls, but then the paint comes off too easily. The real estate agents don't seem to mind, but a homeowner wouldn't be too happy after a couple months.
So, any paint sticky enough to just go over it without pre-scuffing? Especially any mid-range paint, price-wise. (BTW, we were changing colors, such as tan to beige, etc.)
Thanks much.
MarkJames is offline
Old 05-31-2013, 06:56 PM   #2
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 6,794
Re: Paint Over Eggshell
Was the previous coat an oil or latex based paint? Latex goes fine over latex with no sanding needed.
Caslon is offline
Old 05-31-2013, 08:21 PM   #3
The Sheriff
Jaws's Avatar
Rewards Points: 2,028
I use SW Super Paint or Duration, 200 if its low end. Clean the surface and it works fine.
I dont self perform paint, but have seen good results from the crew.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 05-31-2013, 08:57 PM   #4
MarkJames's Avatar
Yes, going over latex.
Thanks for the replies.
Old 05-31-2013, 09:09 PM   #5
The Sheriff
Jaws's Avatar
You will be fine going over Latex, two coats.
John
Jaws is online now
Old 05-31-2013, 10:13 PM   #6
hdavis's Avatar
Rewards Points: 3,655
No problem, as long as it isn't greasy / dirty. I've seen more problems with the underlying layers delaminating than a decent new coat of paint.
In this situation, pole sanding really only knocks of any little bumps on the wall, so you get a slightly better looking job.
hdavis is online now
Old 05-31-2013, 11:14 PM   #7
Caslon's Avatar
A drastic color change may need two coats as the finish paint might tend to slip off as it's applied.
Caslon is offline
Old 05-31-2013, 11:18 PM   #8
The Sheriff
Jaws's Avatar
Admittedly not a painter, but imo, always two coats. Holidays otherwise ......
John
Jaws is online now
The Following 4 Users Say Thank You to Jaws For This Useful Post:
Sir Mixalot (08-13-2013), TAHomeRepairs (06-01-2013), tenon0774 (05-31-2013), ToolNut (08-18-2013)
Old 05-31-2013, 11:33 PM   #9
Caslon's Avatar
Not always if the colors are very similar.
Caslon is offline
Old 05-31-2013, 11:40 PM   #10
The Sheriff
Jaws's Avatar
As a GC, IF I sub paint, its always 2 coats...
John
Jaws is online now
Old 05-31-2013, 11:44 PM   #11
Caslon's Avatar
As a painting contractor, I'm not that automatic. I know when it will need an additional coat beforehand tho. Sometimes it doesn't.
Caslon is offline
Old 05-31-2013, 11:56 PM   #12
Mile011's Avatar
Trade: home improvment
In my expiriance
Using low end paint it always requires two coats, sometimes more, lol
Mile011 is offline
Old 06-01-2013, 12:02 AM   #13
Caslon's Avatar
Originally Posted by Mile011 View Post
In my expiriance
Paint coverage speaking, low priced paints have more solids in them (less vehicle which adds cost). They cover great but wear poorly. You can't really wash the wall, the paint comes off on your rag.
Caslon is offline
The Following 2 Users Say Thank You to Caslon For This Useful Post:
Californiadecks (06-01-2013), Frank Castle (06-01-2013)
Old 06-01-2013, 06:31 AM   #14
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,124
As a matter of routine I run a pole sander over the walls, it removes the lumps and fuzz and scuffs the walls. If there are any additional concerns over the walls such as grease etc then I was with tsp.
I always put on two coats with SW Superpaint being my go to paint, I can upgrade to Duration when requested or downgrade to Promar 200 if requested. I don't put on anything less as it usually requires more labor for a less satisfactory job.
I am fortunate that I am no longer doing work for real estate agents or landlords.
Ohio painter is offline
The Following 2 Users Say Thank You to Ohio painter For This Useful Post:
CarpenterSFO (06-02-2013), joethepainter (06-01-2013)
Old 08-08-2013, 09:21 PM   #15
KDPaintingCT's Avatar
Trade: Painting Contractor
Rewards Points: 12
Post
There is no need for sanding in my opinion. You could wipe walls down if they seem dusty, apply two coats of quality paint and you should be good.
KDPaintingCT is offline
Old 08-09-2013, 12:12 AM   #16
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Sprayed w/ a 515 tipsize. None of that silly talk of whole wall sanding, just basic prep. One coat.
It honestly boils down to your clients expectations, not your paint. I give up on being a painting diva. On a scale of 1-10 most are fine with an 8. Just keep those lines crisp.
Paint quality wise, once again I'm not even gonna bother arguing. Just go to the nearest supplier and ask for their mid-grade stuff. It's all pretty close, and only those concerned w/perfection will care.
Valspar, Sw, glidden, BM those are the brands you want.
But i'm a hack who only does rentals, so don't listen to me. Haha
www.callbathdoctor.com
Driftweed is offline
Old 08-12-2013, 10:58 PM   #17
Rbnsb5's Avatar
Trade: Custom Colors & Wall Design
Rewards Points: 75
Yeah. Only sand those walls out if the last guys shed their nap all over the wall. Other than that no sanding should be necc. Your pics are looking good. Nice work. Thumbs up.
Rbnsb5 is offline
Old 08-13-2013, 12:50 AM   #18
Accidental Painter
Driftweed's Avatar
Thanks man, I'm getting better and faster with each job. Always something to learn if you look for it.
I just don't have to put a second coat on very often. Instead, I tell them look at it after the first coat, if you insist then I'll slap another coat on. Only 2 customers out of about 30 so far have made me do a second.
I find that if you lay it on stupid thick (and check for runs/sags 10 min later) you can get away w/ 1 coat on a majority of repaints. If it's gonna run/sag then its gonna do it in those precious first 30 min on the wall.
Painting Siding FrankSmith Painting & Finish Work 40 05-21-2013 09:40 PM
Behr paint is great... lol Mike Finley Painting & Finish Work 132 08-14-2010 11:13 AM
Paint sprayer yields "orange peel" finish BRUCE R Painting & Finish Work 5 05-01-2010 05:42 PM
Best Paint for a Historic Home fatal_degree Painting & Finish Work 15 04-23-2010 09:09 AM
Independent Paint Review? KPSquared Painting & Finish Work 11 04-01-2010 09:23 AM
