Paint Easily Peeling From Walls
Old 01-19-2012, 11:05 PM   #1
904sorock
904sorock's Avatar
Trade: General Building Contractor
Rewards Points: 75
Do you paint pros know what is causing paint to easily peel off a bathroom wall in a house Im working on. How would you suggest I prep and repaint. Thanks SM
904sorock is offline
Old 01-19-2012, 11:07 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,214
Re: Paint Easily Peeling From Walls
I'm not a painter.....but....
wrong paint....or poor or no prep...
griz is online now
Jaws (01-20-2012)
Old 01-19-2012, 11:09 PM   #3
WildWill's Avatar
Rewards Points: 504
Latex over Oil
Poorly primed wall, or not primed at all
Moister trying to escape from walls
That would be my top three guesses.
WildWill is offline
The Following User Says Thank You to WildWill For This Useful Post:
Jaws (01-20-2012)
Old 01-19-2012, 11:13 PM   #4
904sorock
904sorock's Avatar
Rewards Points: 75
What do you suggest I do to fix WildWill
Old 01-19-2012, 11:35 PM   #5
WildWill's Avatar
Rewards Points: 504
Best to wait for one of the paint pros for that, if it's moisture I have several fixes for that.
You can test for moisture int he wall with a cheap moisture meter.
Can get on at most paint stores.
WildWill is offline
Old 01-20-2012, 12:19 AM   #6
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,776
Oil over latex is not a problem.
Latex over oil is a problem, but that is probably what Bill meant.
Scrape off as much as you can that is loose. feather in the edges ,with a random orbit if nessissary. Sand all surfaces really well, and prime with a top notch oil primer. If the surface is not great, you may have to skimcoat with a classic finish mud, ( not a general purpose). Spot prime those areas. Sand and paint with a GOOD latex paint.
Should be good to go.
An alternate method would be to tear out all drywall and start again
B.D.R. is offline
The Following User Says Thank You to B.D.R. For This Useful Post:
WildWill (01-20-2012)
Old 01-20-2012, 12:37 AM   #7
904sorock
904sorock's Avatar
Rewards Points: 75
BDR is oil primer a must. Its gonna stink up the house for days
Old 01-20-2012, 01:22 AM   #8
B.D.R.'s Avatar
Yes. I would not recomend anything else.
The smell really isn't that bad.
Close the door and leave the fan on if nessissarry
B.D.R. is offline
Old 01-20-2012, 05:29 AM   #9
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
kinda depends on where it is peeling, If it appears to be where showering and mist have gathered then you know it is lack of adhesion due to soap and if it is just the ceiling , then water leaks but all over the wrong paint, Ive even seen latex to latex not adhereing, buy some acetone, and see what layers are what for starts. Just covering it with an oil primer won't really do a whole lot, a big hard shell that as a whole is stronger than weak bits. A really sharp plaster patching knife is more effective than sandpaper unless you like painting super dusty-crusty walls
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 01-20-2012, 10:00 AM   #10
B.D.R.'s Avatar
So you don't sand walls before you paint??
B.D.R. is offline
Old 01-20-2012, 12:02 PM   #11
got mixed up with poster, I just meant that sanding off all you can before scraping is a big mess sorry for the mis direction,,, I'll just stay out of it
Old 01-20-2012, 12:52 PM   #12
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,438
You can paint latex on top of oil primer with no problem. You don't usually want to paint oil over latex. Latex is much more flexible than oil.
Test the surface with some deglosser. If paint comes off it is latex.
In either situation use an oil based primer and then you can paint with oil or latex paint. It will seal the surface much better than water based primers.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
The Following User Says Thank You to TNTSERVICES For This Useful Post:
Old 01-20-2012, 02:41 PM   #13
Professional Tradesman
GPI's Avatar
Trade: Painting-Wallcoverings-Drywall-Carpentry
Rewards Points: 250
Best prime with BIN white shellac, will promote great adheasion plus act as a vapor barrier.
GPI is offline
Old 01-20-2012, 04:18 PM   #14
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
OK guys - I thought I knew this but now I am confused and unsure
Grace is bestowed upon the soul - not upon the ego.
RS Sam is offline
Old 01-20-2012, 04:27 PM   #15
Hair Splitter
Trade: General
Have you ever grabbed a can of the Kilz or Zinnser primer in a spray can to cover a water stain and then paint flat white latex on top? Works just fine and the can is an oil based product.
But I am just talking about primers. I wouldn't paint a latex product on top of an oil based paint. I would use an oil based primer first.
RS Sam (01-20-2012)
Old 01-20-2012, 04:39 PM   #16
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,346
I have seen paint peel around showers due to either dusty walls when painted, no primer, or both. Is it peeling everywhere? Is it peeling off and exposing the drywall or another layer of paint?
SuperiorHIP is offline
Old 01-20-2012, 04:46 PM   #17
Hair Splitter
Trade: General
Pics would help as well.
Old 08-30-2012, 03:38 PM   #18
VaporLock's Avatar
Trade: general
To take this in a slightly different direction, if you *wanted* the paint to peal off the walls (eg, to make brick look like it'd been painted decades ago), would sealing the wall (brick in this case) with a clear oil-based primer then painting over it with latex paint do the trick?
VaporLock is offline
Old 08-30-2012, 07:52 PM   #19
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
sounds like key word is primer. Moist areas, bathrooms and kitchens, OIL. Shellac based is more for covering stains than adhesion.
ToolNut is offline
Old 08-30-2012, 07:56 PM   #20
Radical Basement Dweller
Robie's Avatar
Rewards Points: 10,284
Yup...I've experienced this twice...the first time and last time. When first starting out, I repaired a ceiling and did not get the drywall dust off before priming. I went back to give a second coat of paint a few days later and the paint pulled right up with the roller. I brought in a pro and he told me what the problem was. Haven't had the problem since.
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Paint or stick with solid color stain? JL1 Painting & Finish Work 46 01-16-2014 05:58 AM
Which paint???? izzy Painting & Finish Work 18 04-30-2010 09:03 AM
paint peeling nlgutters Painting & Finish Work 10 04-12-2009 11:45 AM
Latex over Oil base paint is peeling iceman61 Painting & Finish Work 19 10-15-2008 11:44 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
