Paint Cleanup With A Septic System
Old 04-21-2005, 01:43 PM   #1
robertc65's Avatar
Trade: Former Electrician
I have never had a septic system but I do now. I have read that you should not pour any chemicals down the drain including paint. How do you guys cleanup when the house you are painting has a septic system.
Rob
robertc65 is offline
Old 04-21-2005, 11:08 PM   #2
Don
donb1959's Avatar
Trade: Paint Contractor
Re: Paint Cleanup With A Septic System
I bring my stuff home and clean up.
I fish therefore I am
http://www.shimmerz.biz
donb1959 is offline
Old 04-21-2005, 11:43 PM   #3
Teetorbilt's Avatar
Like don, put everthing in plastic grocery bags and take home.
I'm on septic too. My utility sink goes to a french drain along with the washwater.
Albert Einstein
Teetorbilt is offline
Old 04-22-2005, 11:21 AM   #4
robertc65's Avatar
Since it's home I need to paint I guess I can skip the plastic bags.
Teetorbilt So does this mean your sink water ends up in the sump. I guess the sump dumps into the grass outside somewhere Uh?
Old 04-22-2005, 10:49 PM   #5
Teetorbilt's Avatar
The water is diverted to a plastic, perforated, 55 gal. drum set to ground level and filled with local stones.
The water eventually makes it way back to the water table. The ground around it provides the filtering medium
Albert Einstein
Installing Septic System SMKFULLER Excavation & Site Work 8 04-03-2008 09:23 PM
Living Filter Septic System jmic Excavation & Site Work 18 07-20-2007 09:31 PM
Septic system construction. gdavis Excavation & Site Work 5 02-04-2007 03:29 PM
