Trade: Painting Contractor
Outside Air Temperature
Painting contractor located in the midwest and temperatures are mid 30's this week. We have two houses to finish on the exterior and I was looking for input if anyone has used ICI Dulux exterior paint. Can be applied down to 32 degrees but have never used the product. Would also be willing to switch to a Sherwin-Williams brand as long as product durability is not compromised. Trim of both homes is cedar and we are using a latex solid color stain; body of house is dryvit (stucco) in a venetian plaster type application. We are almost completed with the trim and the dryvit is what we need to start and complete before the temperature really drops. Thanks for the input.
Dripless
Trade: Painting and exterior wood care
Re: Outside Air Temperature
How cold has it been getting at night? I think the 32 degree line is for surface temp not air temp. You're into it now and you have to finish, so just do it and hope for the best.
I use an temp meter for my own piece of mind (and the clients are really impressed). You can get a basic infra red meter from Gardner for under $40. |
Trade: restorations
Make sure you anticipate what the temp is going to do after you paint. If it's 35 degrees at 5pm, you are going to have a problem, since the temp will surely drop at night. The best thing to do in cold weather is to start in the morning since the temp usually increases throughout the day.
As far as using ICI Dulux, don't do it. It sucks. Been there done that. Get yourself some Sherwin-Williams exterior super paint, rated to go on at 35 degrees. Bret |
| Temperature rating of pipe | JohnJ0906 | Plumbing | 1 | 07-29-2007 04:11 PM |
| Condensation Help | Patrick | Windows, Siding and Doors | 10 | 03-16-2007 09:40 AM |
| Bondo and temperature? | Kashmir | Painting & Finish Work | 2 | 01-26-2007 09:40 PM |
| Home ambient temperature | rikanit | HVAC | 3 | 01-16-2006 01:31 PM |
| How Water Temperature Control Valve | Robie | Plumbing | 1 | 12-15-2005 07:28 PM |
