Outdoor Paint
Old 05-25-2009, 08:23 PM   #1
Gilby's Avatar
Trade: Roofing Contractor
Outdoor Paint
I am just wondering what kind of paint would be best to paint metal outside. I am painting my shed and its one of those tin sheds I tried some fence and barn paint but it dont seem to work that well anyone have any ideas
Gilby is offline
Old 05-25-2009, 08:33 PM   #2
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Re: Outdoor Paint
Exterior alkyd enamel
ModernStyle is offline
Old 05-26-2009, 01:10 AM   #3
sparehair's Avatar
Trade: Painting, flooring
Re: Outdoor Paint
give the paint time to cure as well. weeks or months
sparehair is offline
Old 05-26-2009, 02:16 AM   #4
Estimator
DavidNTX's Avatar
Trade: Estimating
Re: Outdoor Paint
What is on the tin now?
DavidNTX is offline
Old 05-26-2009, 09:40 AM   #5
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Re: Outdoor Paint
Oil and tin don't mix that well. You'd be better of with an acrylic DTM.
http://www.morrispaint.com
gideond is offline
Old 05-26-2009, 11:23 AM   #6
Estimator
DavidNTX's Avatar
Trade: Estimating
Re: Outdoor Paint
Chances are it is galvanized metal which would require a primer before using an alkyd. Acrylics generally hold up well on galvanized sheet metal and would work well on unpainted galvanized.
If it isn't very old there is a good possibility that the material is aluminum in which case a bit more care should be given. Some acrylics work well on aluminum. DTM does and there are others.
If the surface is already coated then it needs to be cleaned and topcoated, depending on what is on it now. Sometimes when you put a waterborn product on a prefinished metal siding it takes about 10 days for the new coating to cure out completely and adhere good to the old coating. Until that time it can sometimes be peeled off with a fingernail.
Alkyd enamel will only work if the metal has been primed or has a previous coating on it. Acrylics will still do a better job and last longer on "tin".
DavidNTX is offline
Old 05-28-2009, 09:58 AM   #7
Paul Painter's Avatar
Trade: Historical restorations painter/plaster
Re: Outdoor Paint
I would use DTM (Direct to metal)..treat any areas with rust first with red oxide primer...if none present,great...wash surfaces to be painted and try to paint on a cloudy (not rainy) day..direct sun not good!!
Paul Painter is offline
Old 05-30-2009, 09:02 PM   #8
jmda
jmda's Avatar
Trade: Painter
Re: Outdoor Paint
I agree any DTM. I just painted a couple of tin roofs using Porter acrylic DTM with good results.
Coronado has an excellent product call Rust Scat, but it only comes in semi gloss and gloss
jmda is offline
