Orange Peel On Doors
Old 03-22-2007, 09:15 PM   #1
aspenpainting's Avatar
Trade: int/ext painting
today i sprayed out a bunch of doors and all look like glass except a side on one door. i was to close, left it heavy and it was starting to sag. i took a foam roller to it since the paint was still wet but it had already tacked up just enough to make it look like an orange peel. im assuming the fix is to sand it down tommorrow and repaint. any advice or warning?
aspenpainting is offline
Old 03-22-2007, 09:33 PM   #2
My custom title
Brushslingers's Avatar
Re: Orange Peel On Doors
Latex or oil?
Benn
Originally Posted by Brian
Brushslingers is offline
Old 03-22-2007, 09:48 PM   #3
latex
Old 03-22-2007, 09:49 PM   #4
My custom title
Just scrape em with a 5 and feather out with sanding, will look ok.
Benn
Old 03-22-2007, 09:52 PM   #5
Workaholic's Avatar
Trade: Painting Contractor
I agree with this as well, unless it is a flat panel door. If it has the fake grain then sanding it will be fine.
Sean
Workaholic is offline
Old 03-22-2007, 09:55 PM   #6
its up and down the whole side will that still work?
Old 03-22-2007, 09:56 PM   #7
six panel door
Old 03-22-2007, 10:00 PM   #8
My custom title
Shouldn't be a problem, use your 5 to hit the highs and smooth it down from there.. latex normally isn't a problem to scrape on a new door.
Benn
Old 03-22-2007, 10:02 PM   #9
excellent as always this site and the painters in it are always there to lend a helping hand thanks guys
Old 03-23-2007, 08:39 AM   #10
Traditions's Avatar
Trade: painting
probably won't be able to sand that quickly though. Need to let the paint cure or it will gum up.
Traditions is offline
Old 03-24-2007, 06:55 AM   #11
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
or, use some of the green 3m latex sandpaper,,,works great and does'nt load up as fast.
painterofeveryt is offline
Price per sq. ft Knockdown and Orange peel dwbrooks Drywall 25 08-27-2011 04:57 PM
orange peel finish scottstef Drywall 4 07-22-2011 04:43 AM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 06:24 AM
Oil Based Paint leaving wrinkly finish on doors dwbrooks Painting & Finish Work 8 11-09-2005 11:29 PM
