Trade: residential remodeling
Old School Roller, New To Spraying
i've rolled and brushed for 22 yrs and i just bought my first sprayer. it's a graco 190es. i used it on ceilings and works great BUT when i used it on walls, all i saw was lines everywhere. I NEVER LEAVE LINES with a roller. i used 513,515, and 517 tips and still have horizontal lines with even two coats of flat promar 200. i did thin the paint with water as i was told by a hd employee who sounds like he knew something. should i thin the paint?? i did set the psi on various levels and still get the outer lines. the filters were both clean too. someone please help this old school painter with a new trick.
thanks. |
#2 | |
House Painters Reading PA
Re: Old School Roller, New To SprayingQuote:
#3 | |
My custom title
Most lines are caused by gummed up guards... not tips. However, backrolling is the only way to go with spraying.... otherwise you can't touchup without it looking like A**. I crosshatch primer, which makes most of it dissapear but, I still backroll ANY finish.
Benn Quote:
Trade: paint
the last time I used PM200 I was doing a color change in apartments. Both me and the main contractor were having issues with lines. So I would lay down a base coat and he would come back with a light mist to cover the lines and feather in another coat..........the point is ....... I was reading on the bucket AFTER THE JOB that PM200 requires a .019 tip or bigger, or so it says on the bucket. try that and see it that works.
missed a spot
Trade: Paint contractor
The advice you got from these guys is right on, but pro mar 200 flat SUCKS especially when spraying it. I have used alot of is on a spec. job and I will never use it again. The pro mar 400 flat is great works much better. Also, if the pro mar you are using is an illuminious base...it is even harder to use. Always backroll.
thanks benn.... but won't "back rolling" take longer than just rolling without the sprayer and the clean up time?? just wondering
no kidding... it was an illuminious base!!!!!!!!! also promar 400 is better in flat???
i just read the back of the gallon container and it did read ".17 - .21 tip. i guess i'll try the .19 tip anyway.
#9 | ||
My custom title
Benn Quote:
my only problem with that is i work alone. thats why i was wondering if it would take longer. but if it even takes twice as long and comparing with dipping, rolling, and cutting in ; i guess it's still quicker...
i have a 3200sqft house i'm starting monday BUT all the bedrooms and DIFFERENT COLORS!!! I don't think i'll be spraying all the walls; just ceilings. |
Trade: paint
Re: Old School Roller, New To Spraying |
thank you all for the great advice.
i guess i'll just have to earn some experience with my new toy.AND BUY A NEW LARGER TIP. this 190es states it can only use up to .19 tip max. and the instructions state that if i still get lines and my spray to use a smaller tip. go figure... i call them not instructions but destructions |
#13 | |
My custom title
Naaa, just get a 619 and a whip... your paint dealer will know what your asking for when you say that. Trust me
Benn Quote:
man i gotta tell ya.... you guys are great. i'll be gettin the 619 monday at sw. why would the damn sprayer come with a 515 anyway?? so i would have to spend more money thats why!!!!!!!!!!!
missed a spot
not to take your advice seriously but is there anyone else that agrees that the promar 400 flat is better that 200??? just wondering
i do appreciate your time and effort. |
i meant that i do take your advice seriously but just wondering if anyone else feels the same
#18 |
missed a spot
don't misunderstand me I am only talking about flat. 400 better than 200. We use it on all our ceilings its great.
#19 |
Trade: paint
Joe for as far i know the 515 is the most common tip use for standard wall repaints............ also when you get your '19' start with the pressure about 1/2 to 2/3 of the way up and tweak from there.
I have also had "lines" but when it dries the lines go away and you never see them. let us know how it turns out |
#20 | ||
My custom title
Cause you need the whip.. heh. Ya it will PUSH a .021 but you need a whip to do it.
Benn Quote:
| One more airless power roller question | steve-in-kville | Painting & Finish Work | 5 | 09-19-2008 11:09 PM |
| Titan power roller... My first impressions | steve-in-kville | Painting & Finish Work | 0 | 06-17-2007 11:22 AM |
| Dried roller cover removal? | steve-in-kville | Painting & Finish Work | 17 | 04-12-2007 08:26 AM |
| old school roller, new to spraying | remodeling joe | Painting & Finish Work | 18 | 03-01-2007 12:51 AM |
| Roller marks in dark paint. | cutnroller | Painting & Finish Work | 10 | 08-03-2006 11:09 PM |
