Oil Tank
Old 05-14-2006, 08:25 PM   #1
Painters Plus's Avatar
Oil Tank
I have a homeowner who wants there exterior oil tank painted the same colour as there house. The tank now looks brand new with a glossy gray finish. Any suggestions on prep and paint to tackle this job?
Thank you!!
Painters Plus is offline
Old 05-15-2006, 09:21 AM   #2
simmons's Avatar
Trade: painting
Re: Oil Tank
Chances are the finish is either epoxy or epoxy/polyurethane. Either way you'll need to de-gloss by lightly sanding.Best way to top coat would be with a polyurethane. There are some easy to use urethanes some of which are alkyd, aliphatic(uses a hardener), and moisture cure. Check with your coating supplier for reccomended compatablility for fuel oil. BE SURE to de-grease the tank before sanding! good luck!
simmons is offline
Propane tank relocation... ruskent HVAC 4 03-19-2007 01:05 AM
Oil Tank KGB HVAC 1 03-18-2007 08:54 PM
holding tank MarcM8181 Plumbing 2 08-17-2006 06:08 PM
Expansion tank on water heater Teetorbilt Plumbing 5 04-17-2006 01:53 PM
oil tank location question Vermonster HVAC 3 10-19-2005 09:14 AM
