Oil Or Latex With Floetrol For Hobby Project
Old 06-17-2006, 01:09 AM   #1
415moto's Avatar
Trade: General contractor
Im making some MDF stands to display some hobby stuff and I was going to roll them. Simple satin finish in a dark color, likely black.
What do you guys think would be better for durability (wipe downs) and smooth finish with a roller? Oil like BM Satin Impervo or a latex with floetrol?
Im looking for maximum smoothness and imperfection coverage (its mdf)
any 2 cents to throw in ? I was going to use the oil, but after hearing about the floetrol..kinda leaned toward that.
415moto is offline
Old 06-17-2006, 01:55 PM   #2
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Re: Oil Or Latex With Floetrol For Hobby Project
The latex with floetrol would be the easiest in terms of application and clean-up. Use a small nap roller, like 1\4 inch
With an oil based enamel you are going to get a much more durable finish. I also like the flow out and leveling properties of higher quality oils.
So it comes down to what you are going to put in the cabinet. Are the items going to be changed out all the time or put there and left? If it's the latter should have no trouble with using a latex.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 06-17-2006, 02:09 PM   #3
Painting Contractor
What kind of paint are you planning on using?
The NAPP
Old 06-17-2006, 02:18 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
I like oil myself (love the Impervo), but the waterborne enamels today are pretty good
Signature Quote
slickshift is offline
Old 06-17-2006, 05:42 PM   #5
KellyPainting's Avatar
I'd even take it one step further.. instead of a nap roller, use a styrophome (spelled wrong) or synthedic roller nap.. a nap roller w/ hairs will leave even a slight texture to your project... and remember to get TRUE color, you must prime w/ a grey primer.. and the hot blacks of this year are ebony black and piano black. you will see them on everything from electronics to cell phones.... I just did garage doors that color and they looked great.
KellyPainting is offline
Old 06-18-2006, 05:04 AM   #6
415moto's Avatar
thanks for the advice all.
it sounds like i cant go wrong with either.
its really not going to get any movement or wear and tear so I suppose latex with floetrol is going to be my best bet.
ill use the styrofoam roller idea and see how that works.
415moto is offline
Old 06-18-2006, 07:44 AM   #7
Robie's Avatar
If you do decide to go with oil, there is a product called Penetrol, I think from the same company that makes Flotrol to thin the oil-based paint out.
I use it a lot it hot weather so the paint doesn't get too thick, too quick.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Robie is offline
To all The Newbies Starting Up Their Own Business dirt diggler General Discussion 53 04-27-2011 07:21 PM
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 07:59 AM
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 06:38 PM
Project Manager/Project Engineer ComConRecruiter Help Wanted or Looking For Work 0 03-28-2007 03:42 PM
