Old 02-04-2008, 06:45 PM   #1
Trade: Handyman Service
Smile Oil base on top of water base stain for wood floors
Hi everyone
I have a customer who wants water base stain and an oil base poly on top.
I have always used the same base for both. Can Oil base poly go on top of waterbase stain?
Thanks in advance. ( wood floors)
Frank11613 is offline   Reply With Quote
Old 02-04-2008, 07:53 PM   #2
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
Not sure, i would ask either manufactuers if the two are compatible
www.perfectocorp.com
plazaman is offline   Reply With Quote
Old 03-06-2008, 07:52 PM   #3
Oil on water
From what I've learned: Generally, you can put a water base on top of an oil base but not the other way around. The reason for this is that water based products retain some flexibility when cured, while oil-based products do not. SO, if the base flexes the oil topcoat can crack.
kenscar is offline   Reply With Quote
Old 03-06-2008, 08:03 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
Yes
Signature Quote
slickshift is offline   Reply With Quote
water stain pipe or roof? GWHRsuperhero Roofing 2 04-24-2007 07:43 PM
solid base stain or semi trans on deck Traditions Painting & Finish Work 14 04-01-2007 07:57 PM
Stain wood floors navco1390 Flooring 3 03-01-2007 09:48 PM
Removing a hot water base board heater Mike Finley Plumbing 8 01-23-2007 07:51 PM
Oil base or water base poly? jhf469 Flooring 4 11-24-2006 11:36 PM
