Trade: Painter
Oil Base Exterior
I have a large exterior wood frame house to paint,looks like it has not been painted in 20 yrs.It has on it now oil-based paint that is just hanging,ready to fall off.My question is,should I use 1-2-3 latex primer,then come back with Duration or just use 2 coats of Duration,the first being the primer coat.Dont know how well duration sticks to oil base paint.The color is white.Thanks
#2 | |
Pro Painter
Re: Oil Base Exterior
Honestly, I would use an oil or alkyd primer first, and then the Duration top coats. I know they say self priming, but if you want it rock solid, I would suggest an oil primer, then the Duration....especially for something that is failing badly already. Make sure you feather sand the edges of the peeling paint to a sound surface because no product you use is going to bridge the edges of cracked paint for long.
Professional Painter
Trade: Owner/Operator
yeah...what he said, exactly....god I'm happy to see you're using SHERWIN!
Trade: Painting Contractor
I'll 3rd that... oil primer...then 2 top coats
Trade: Painter
Guys,I originally had thought the same thing,in fact it is what i had always done in the past,but the last house I did that was similiar, the oil base primer formed an impermeable film that became brittle and cracked and broke into large chips.I thought maybe the 123 bullseye latex primer would breathe and flex and not cause a rapid peeling problem.Just my opinion.Thanks Doug
painterofeverything
some say thats the problem with the oil based primers, they do not let the water vapor escape from the inside to the outside,therefore causing the primer (and topcoat to get) "pushed off "from the inside out.....just passing on what I have heard.
#7 | ||
Pro Painter
Re: Oil Base ExteriorQuote:
My $0.02....
I've had alot of succes w/ oil primers....but you got to apply to a bone dry house...otherwise your trapping the water... and remember...oil dries from the inside out! not like latex (from the outside in) so on hot days... it might take a day or two for the oil to set up correctly...
#9 | ||
My custom title
Benn Quote:
| Exterior Wall Sheathing in B.C., Canada? | wallmaxx | Framing | 9 | 01-21-2008 01:10 AM |
| Sub Base for pavers | mcgyverdc | Landscaping | 20 | 01-14-2007 02:48 PM |
| Saw to cut Base Board vertical | 415moto | Tools & Equipment | 28 | 12-18-2006 08:08 PM |
| vendors for oil base. | mdshunk | Painting & Finish Work | 5 | 11-11-2006 08:34 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
