Non-darkening Clear
Old 01-30-2018, 06:10 PM   #1
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 824
Non-darkening Clear
My current project has large Doug fir timbers. The previous finish has been sanded off and they are currently bare. After seeing them in their current state, my client and designer like them as they are. Any input on what I can use to finish/protect them that won't yellow and darken the natural, sanded look? Waterborne lacquer? Water based floor finish like a Bona product?
overanalyze is online now
Old 01-30-2018, 06:47 PM   #2
tjbnwi's Avatar
Rewards Points: 2,936
Re: Non-darkening Clear
A good water bourne. Pick your favorite and have at it.
tjbnwi is online now
overanalyze (01-30-2018)
Old 01-30-2018, 07:27 PM   #3
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 392
Look for, "Water White" in the title. All oils will amber, and some water-based products do as well. General Finishes makes a High Performance WB that's pretty good. And as much as I like Bona for floors, (Bona Traffic), I wouldn't use it on vertical pieces. You'd probably end up with lots of runs.
Make sure they know that any topcoat might make the wood look darker. Tell them to just wet a piece of the raw wood, and let them know that's what they can expect from a topcoat.
Troy Stevens, Stelzer Painting Inc.
www.stelzerpainting.com
stelzerpainting is offline
Old 01-30-2018, 07:39 PM   #4
Always Learning
Rewards Points: 824
That is the issue...when I wet it they don't like the look.
Old 01-30-2018, 09:06 PM   #5
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,224
Fir will darken quite a bit even without coating. So you need both a clear finish and one that blocks as much UV as possible.
Golden view is online now
Old 01-30-2018, 09:26 PM   #6
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,194
Yep, no matter what you put on them, they won't look like they do now with time.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Golden view (01-30-2018)
What kind of finish to put on fir beaded ceiling and clear pine fascia? Cornerstonecon Painting & Finish Work 4 04-24-2017 06:35 PM
First time ZackyBundles Drywall Picture Post 155 02-07-2013 07:11 PM
Clear coating question (High Temp)? MasterBlaster Sandblasting 3 01-17-2013 06:35 AM
Clear coat alligatored!! creativeaddict Painting & Finish Work Picture Post 1 11-27-2012 07:44 PM
Baking Soda Blasting Pine with clear ECRSS Sandblasting 11 05-02-2011 12:15 AM
