Old 04-10-2007, 04:22 PM   #1
Nicotine stains
Hello all,I am painting an interior rental property next week and the property has been trashed,the worst part is the walls and ceilings are covered with heavy nicotine stains.I am wondering what is the best product to clean the walls with and the best primer to seal the stains.Thanks Doug.
corky is offline   Reply With Quote
Old 04-10-2007, 04:59 PM   #2
Professional Painter
Richard's Avatar
Trade: Owner/Operator
tsp to clean
SW preprite problock to seal
I've done it, these are a perfect combination...you can't and won't go wrong--good luck
Richard is offline   Reply With Quote
Old 04-10-2007, 05:38 PM   #3
Trade: Painting & Remodeling
Clean it first then use kills original on everything.
BMAN is offline   Reply With Quote
Old 04-10-2007, 06:22 PM   #4
My custom title
Brushslingers's Avatar
Originally Posted by Paintguy26 View Post
tsp to clean
Agree.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 04-10-2007, 07:03 PM   #5
KellyPainting's Avatar
Trade: Painting Contractor
2 packs a day.... check out my ceilings
http://www.contractortalk.com/attach...1&d=1176249723
KellyPainting is offline   Reply With Quote
Old 04-11-2007, 12:16 AM   #6
paintr56's Avatar
Trade: paint contractor since 1974
Tsp to clean Gripper from ICI to prime. make sure you let it cure for 24 hours before painting.
Jim Bunton
paintr56 is offline   Reply With Quote
Old 04-11-2007, 07:17 AM   #7
MakDeco's Avatar
I was going to Say TSP then B-I-N to prime.
MAK Deco
MakDeco is offline   Reply With Quote
Old 04-11-2007, 04:14 PM   #8
rws
Send a message via AIM to rws
I also use Bin but not tsp as Zinnzer says not to wash with it if using 123 or BIN.In severe cases oil based stain killers can reactivate the oils in the stains causing bleed thru.
rws is offline   Reply With Quote
Old 04-13-2007, 06:27 AM   #9
Trade: Painter
Kids, you don't know where that money has been!
And then...
After doing all that...
high humidity can cause it to seep through anyway!
This nicotine is one of the reasons I got out of apartment painting!
I was asked to look at an apartment that was totally orange (not paint). There was orange ash in the carpet... window frames... puke! Oh, and it had popcorn ceilings! I happened to have my wife and kids with me and let them look through the door to see how some live. I also found some money on the carpet and asked my kids if they wanted to put it in their mouths. They said no, of course! I said that this is one reason why you don't put money in your mouth! You don't know where it's been... except now you know one place it may have been!
I used TSP substitute (twice) and used BIN... 2 coats. Oh, and it's kind of hard to wash popcorn ceilings (if anyone has any bright ideas, let us know) Nicotine absorbs into the walls and will act as a time-release even after using TSP or the no-rinse substitute and sealing. I've talked with other guys who have also tried different things. Several of them had gotten complaints that the bathrooms bled. It seems to be the humidity in there.
I started weasling out of these jobs by getting too expensive. The money was good, but the jobs stunk...literally. I've done rentals where the nicotine was running down the walls... I wanted a higher quality of life... blah...blah...blah...
TimAZ is offline   Reply With Quote
Old 04-15-2007, 11:40 AM   #10
nicotine stains
Thanks everyone for the good info.Sounds like everyone has had the misfortune of painting over nicotine.I was wondering if anyone has used coverstain or kilz oil oderless and if they have worked.Thanks Doug
Old 04-15-2007, 02:13 PM   #11
Richard's Avatar
corky
kilz is a bad word in here
the cover stain should work fine...actually, check out the site for yourself http://www.zinsser.com/primerapps.asp
Rich
Nicotine Coating Wolverine-Eric Specialty Coatings 15 11-01-2008 01:23 AM
Mineral Stains On Brick BAREBACK Pressure Washing 4 03-14-2008 07:53 AM
removing water stains quality app Painting & Finish Work 7 12-19-2006 06:59 PM
Rust stains on stucco locofoco Construction 3 07-31-2006 09:27 PM
Cedar stains googen9 Painting & Finish Work 5 05-14-2006 03:34 PM
