New Base & Shoe Over New Wood Floor
Old 07-27-2008, 12:35 AM   #1
sprayer48
sprayer48's Avatar
Trade: General Contractor, Remodeling.
Hey guys, need some advise please.
I am painting new construction. White trim.
The Architect for the project mandates that I spray all trim, doors, casing, crown, base and shoe.
Question is how do i spray the base and shoe with the wood floors and door jambs already installed. Taping the floor off usually is not clean. paint always finds its way under the tape.
Anyone have any suggestions please. the general contractor advises me that spraying all trim is mandatory.
sprayer48 is offline
Old 07-27-2008, 04:44 PM   #2
sprayer48
sprayer48's Avatar
Re: New Base & Shoe Over New Wood Floor
come on... someone out there has some advise for this situation....
Old 07-27-2008, 08:03 PM   #3
Jerdog44's Avatar
Sometimes you can get a 2" blue tape to fit under the shoe just a hair. It will prevent any visible overspray if you can. Then put a 9 or 12" paper and tape over that with your masker. Then you can cover the rest with plastic and/or drop clothes. If not, I would convince this person that you have to brush the baseboard. It's not very noticeable to brush just the base. We do it all the time.
Jerdog44 is offline
Old 07-27-2008, 08:13 PM   #4
genecarp's Avatar
next time spray it before install. if it is down already and it must be sprayed tape it off as jerdog said and go. no magic available
genecarp is offline
Old 07-27-2008, 09:26 PM   #5
DeanV's Avatar
Trade: Painter
I prefer to mask off wood floors and have the shoe and all trim installed prior to doing any trim painting. This is how you can have the best quality finish for new construction. If you press the tape down carefully, you may have a little paint get through if the tape lifts at an edge, but not much.
DeanV is online now
Old 07-29-2008, 10:04 AM   #6
Frankawitz's Avatar
I would use blue tape at the shoe and use a 5 in 1 to press the tape edge, then I would take my masker with 9" paper and go over the blue tape, then cover that with red rosin paper with 2" masking tape over the rest of the floors. then set sprayer up on a good drop.
Frankawitz is offline
Old 07-29-2008, 11:05 PM   #7
sprayer48
sprayer48's Avatar
Thanks guys,
Think I'm going to take your advise and use 2" blue tape under or up to the shoe. Then press down tight with the 5 in-one knife.
got a go
Old 07-29-2008, 11:07 PM   #8
sprayer48
sprayer48's Avatar
thanks anyway, but I cannot spray first. Architect and g/c need it done up.
I think you get the best results finishing after installed, puttied & caulked.
Old 08-01-2008, 12:57 AM   #9
Licensed, Bonded & Insur
ewingpainting's Avatar
I have a great suggestion. MASK AND SPRAY............. hummmmm
Riverside County Painters
ewingpainting is offline
Wood floor finishing HandyMac General Discussion 0 04-25-2008 06:42 PM
Hard wood floor disaster ...HELP... Cisko Remodeling 6 04-10-2008 08:34 PM
water damaged wood floor replacement 72chevy4x4 Flooring 21 03-30-2008 09:39 AM
Oil base on top of water base stain for wood floors Frank11613 Painting & Finish Work 3 03-06-2008 08:03 PM
Help with clear coating a hardwood floor pdiesel5 Flooring 5 11-03-2006 08:56 AM
