Need Paint Help
Old 01-18-2009, 11:38 PM   #1
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Need Paint Help
I was finishing a kitchen Friday, painted maple. The last panel I put in was solid maple white paint. When I screwed it on (from inside the cabinet) the board cracked. I glued it and clamped and its good. Problem is its a catalyzed paint. I brushed some on with no catalyst, used wet dry paper 400 grit and the crack is smooth. Looks good. Now I need to paint the whole slab, 12" X 29.5".
Can I use a hard foam mini roller to get a spray like finish? I will not be using the catalyst because I'm not in a hurry.
I have a pint of paint, so that's plenty to do this job.
I don't know how to spray paint. At least not professionally.
Also this paint cleans up with acetone, so its pretty forgiving.
It would take 4 weeks to get a new end panel.
silvertree is offline
Old 01-18-2009, 11:47 PM   #2
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
Re: Need Paint Help
The foam brush will get it similar but you can still tell the difference between the pieces if they butt up to each other. I have an air brush and a small paint gun that I can do touch ups and fade the new paint into the existing for a near perfect match.
Static Design is offline
Old 01-18-2009, 11:50 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Need Paint Help
If you can isolate the panel, or mask off all around it, these little things work great:
ProWallGuy is offline
The Following User Says Thank You to ProWallGuy For This Useful Post:
silvertree (01-19-2009)
Old 01-18-2009, 11:59 PM   #4
Workaholic's Avatar
Trade: Painting Contractor
Re: Need Paint Help
I have had good results with the item that PWG posted as well.
I also agree that the foam roller will work better than a brush but next to a spray finish it will be noticed.
Do you have access to a hvlp sprayer?
Sean
Workaholic is offline
Old 01-19-2009, 12:05 AM   #5
Certified Remodeler
silvertree's Avatar
Re: Need Paint Help
I have that thing, I thought they only shot stain. I may have to thin the paint, but its pretty runny already.
Can I skip the catalyst?
I own an HVLP sprayer, but its only a panel side. The panel does not butt up to anything either, it "floats" on the side of the box.
I took the panel with me, and the customer is not too fussy. They were about some things, but I think since this is a base cabinet (cookbook cabinet) and it isn't at eye level I could probably make them happy.
Old 01-19-2009, 12:07 AM   #6
ProWallGuy's Avatar
Re: Need Paint Help
Not sure. What is the exact make/model of your paint?
Old 01-19-2009, 12:30 AM   #7
Certified Remodeler
silvertree's Avatar
Re: Need Paint Help
Don't know, it came from my cabinet maker. They sent primer, catalyst and paint. The paint dries very fast, I think the catalyst is used at the factory.
Damn catalyst cap blew off and hit me in the nose, left a mark too. I was wearing my safety glasses when it happened. I would rather not use it.
But I have no information on the paint. No labels on the cans.
Old 01-19-2009, 08:47 AM   #8
A bit abrasive.
WisePainter's Avatar
Re: Need Paint Help
If it were me I would apply the material with a 3" black foam throw away brush. Care must be taken when applying the material so the coverage is heavy enough to lay out, but not so heavy that it sags after you have left for the day (I really hate that!!).
This is where brush skills matter.
You should not spray it if you don't know how, any issues would make waiting 4 weeks for a new piece seem like the better idea in hindsight.
I have just finished some cabinets where the Darryl and Darryl helpers screwed right through the false fronts of every drawer attaching them to the boxes.
The GC had them come back and fix the problem...sort of, you can see all of the cracks and raised areas.
Seeing as thought the customer is easy going, think this one out before moving ahead.
Mistakes now are not an option.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 01-19-2009, 09:10 AM   #9
Certified Remodeler
silvertree's Avatar
Re: Need Paint Help
Thanks Wisepainter,
I brushed it last night. Light coat, it looks so good from 6 feet away you would think a pro did it. But I need it to look good from 2 feet away.
But it sure looks like a good start.
Foam brush? I have plenty of paint, its worth a try. I cleaned the piece with alcohol before I brushed last night. Surprisingly good for the first coat.
I'm going to post a finished product picture. Didn't take a before shot but the crack was 4" in from an edge and ran about 18".
Old 01-19-2009, 10:07 AM   #10
#1 stunner
Trade: Design/Build
Re: Need Paint Help
If you have plenty of paint and time to mess with it, lightly sand the brushed surface w/400grit, then roll a light coat of paint over the brushed surface, let it dry for manufacture specs, then sand with 1000grit to smooth surface (if you wet the sand paper it want clogged up as much), clean area, then take a car grade wax/rubbing compound to get the shine back on the surface (use a power buffer or your manly pythons).
This technique will smooth out the paint and make it look like sprayed surface, remember to lightly sand: to much and you will see color variation or wood again.
Old 01-19-2009, 03:21 PM   #11
Bender's Avatar
Re: Need Paint Help
If you find that 1st coat is tacky or gummy feeling then you'll know you needed the catalyst.
Bender is offline
Old 01-19-2009, 03:48 PM   #12
A bit abrasive.
Re: Need Paint Help
That almost happened to me.
The SW Manager called me up and politely asked that I return to the store and have my pre~catalyzed lacquer "catalyzed" before I begin spraying...if I didn't already start.
I about freaked.
I politely mentioned that I sure could use a new pair of painter whites, but I am pretty sure they didn't hear me.
I began thinking of the disaster that may have occurred and how I would properly and neatly correct the problem. The SW girl said that it would takes days for it to dry and finish looking terrible.
May I never have to face that problem in the future.
+1 for catalysts
Old 01-19-2009, 04:52 PM   #13
Certified Remodeler
silvertree's Avatar
Re: Need Paint Help
Foam brush didn't work, paint dries too fast and the brush pulled.
Sand and rollers next. Hard foam mini roller.
Old 01-19-2009, 05:12 PM   #14
Certified Remodeler
silvertree's Avatar
Re: Need Paint Help
I didn't see this until I tried without the catalyst. If you count my time, this will be an expensive panel.
Old 01-19-2009, 07:39 PM   #15
A bit abrasive.
Re: Need Paint Help
Time to order the replacement?
Old 01-19-2009, 07:57 PM   #16
Certified Remodeler
silvertree's Avatar
Re: Need Paint Help
I gotta give it a try, Thursday is order day for cabinets, I think I will punish myself for a couple more days. I can appreciate the difference between a painter, and someone who paints.
You know, I worked for 2 years straight with a New England paint pro, old school. I still cleans my brushes (Wooster) the way he taught me. And if I work with anyone that doesn't take care of their paint brushes, I can't stand to watch. The biggest fight I ever had with my wife was when she stuck a brush in up to the wood. My brush. We still don't talk about it
Old 01-19-2009, 10:58 PM   #17
Bender's Avatar
Re: Need Paint Help
catalyst (ktl-st) A substance that starts or speeds up a chemical reaction while undergoing no permanent change itself.
Sorry dude, they sent the catalyst for a reason
Bender is offline
Old 01-19-2009, 11:08 PM   #18
A bit abrasive.
Re: Need Paint Help
Originally Posted by WisePainter View Post
+1 for catalysts
Another +1 for catalysts.
Bondo smells really odd.
Old 04-16-2009, 08:56 AM   #19
brushmasters's Avatar
Trade: Painting, Drywall, Pre-Finishing
Re: Need Paint Help
Great use of feedback on this board. We may have concerns about the paint hardening properly if it is a catalyzed paint. This job is long done but for future reference we are a local paint company that could stop by your job and talk it over with you. Look it up: Brush Masters, Plymouth, MN. We are also members of NARI-MN, try networking with Woody at meetings and we would be glad to discuss painting solutions with you.
brushmasters is offline
Old 04-16-2009, 08:05 PM   #20
Wolfgang's Avatar
Trade: Painting & Remodeling
Re: Need Paint Help
Be a great thing if you could stop by and help Silvertree out. He's always been about the most decent GC type to come into the paint section. I just had some customers of mine getting ready to sell their house and move to Mpls and have offered to refer Silvertree to them. Sometimes it pays to be nice....
Wolfgang is offline
Paint Sprayers BiggersJunior Painting & Finish Work 27 01-12-2009 09:49 PM
cabinet paint of choice world llc Finish Carpentry 8 12-31-2008 08:43 PM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
