Need A Jig To Stand Up Doors
Old 09-04-2008, 07:35 PM   #1
sprayer48
sprayer48's Avatar
Trade: General Contractor, Remodeling.
Rewards Points: 75
Need to know if anyone has some type of a stand or jig to hold doors while I spray paint them.
Seems that some years ago while painting new construction, a painter used some type of a stand that held the doors in place while being sprayed. I always used to lean them against the wall, paint the edges and the one side. Then turn them and finish the job. Then the wall needed to be sanded. a pain.
is there anything out there at all .
thanks
sprayer48 is offline
Old 09-04-2008, 07:42 PM   #2
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Rewards Points: 2,000
Re: Need A Jig To Stand Up Doors
Stand a door up an screw a stick into the top edge, stand another door next to it and make a V , the stick or metal piece goes across the small part of the V.
Nail or screw the doors together.
Look at my "V" and picture yourself looking down on the doors.
They will stay in place.
silvertree is offline
Old 09-04-2008, 07:44 PM   #3
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Rewards Points: 1,014
We just nail 2 peices of scrap wood to the underside as legs, holds good too!
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 09-04-2008, 07:59 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
Your favorite paint store probably has either or both the metal "top attached" kind and the plastic "side attached" kind of "jigs"
They are basically small (no bigger than your hand) pieces that allow you to attach two or more doors together in a "zig-zag" or sorts, standing up, so you can reach both sides
Signature Quote
slickshift is offline
Old 09-04-2008, 08:04 PM   #5
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,205
Yep!! Got mine from Sherwin Williams. They work GREAT!!!!!!!!!!!
I do 8 doors at a time no problem.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 20,000 Subscribers and over 5,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is online now
Old 09-05-2008, 08:02 AM   #6
Traditions2's Avatar
Trade: painting and refinishing
Rewards Points: 150
I use door deckers. They stack the doors flat. IT has a handle on the end so you can flip the doors and stack them up. Takes up very little space. No worry with runs having them flat. I think if you do a search for door deckers you should find them.
Traditions2 is offline
The Following User Says Thank You to Traditions2 For This Useful Post:
pinwheel (05-25-2011)
Old 09-05-2008, 10:37 PM   #7
sprayer48
sprayer48's Avatar
Rewards Points: 75
Picked up the door holders/brackets and some hinge covers today at SW.
Thanks guys. This is going to make all the difference in the world...
One last thing. The house has wood floors. What do you lay down under the doors. Plastic doesn't dry and will fly up when sprayed. just a tarp or take them outside ?
mark
Old 09-06-2008, 06:49 PM   #8
plazaman's Avatar
Rewards Points: 1,202
tarp or other, outiside will likely have dust and other things that will stick to the finish.
you can use that cool stuff from SW or you can go homemade, scrap wood screwd into top of door, make a V,
plazaman is offline
Old 09-06-2008, 07:27 PM   #9
RCPainting's Avatar
Trade: Painting in Utah
I like to spray them hanging. I use hingemags to cover the hinges.
RCPainting is offline
Old 04-09-2009, 01:34 AM   #10
seattlesandmans's Avatar
What are those?
seattlesandmans is offline
Old 04-09-2009, 08:58 AM   #11
RCPainting's Avatar
Just saw this in a magazine
Here are the hingemags, they also sell them at some Sherwin Williams.
Old 05-25-2011, 12:06 PM   #12
joemuth's Avatar
Trade: New home construction
I'm in the process of making a number of paint stands for local painting contractor. This stand allows you to paint the door laying flat and turn it over with one person without touching the door and paint the other side before the first side is dry. I can send you pics if your interested.
joemuth is offline
Old 05-25-2011, 07:22 PM   #13
Painting & Remodeling
JHC's Avatar
Rewards Points: 516
Dangit necro thread got me.
JHC is offline
Old 05-25-2011, 11:19 PM   #14
Santa's Helpers's Avatar
Trade: Repair and remodeling
Rewards Points: 97
You can use saw horse and lay a 2x4 between them. Do the same one more time separating the two 82" apart. Put two screws in the top and bottom of each door and lay the screws on top of the 2 x 4s. You will need two people to flip each door but you can lay them flat this way. It minimizes runs on 6 panel doors.
Santa's Helpers is offline
Cabinet re-face (doors only) back@it Remodeling 12 01-14-2010 03:42 PM
Building Closet doors orson Finish Carpentry 15 08-19-2008 09:01 PM
How many Pocket Doors are enough?? woodbutcher2004 Finish Carpentry 14 02-14-2008 06:47 PM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 05:24 AM
