Need Help: Painting Pool Deck
Old 04-15-2006, 11:18 PM   #1
Guardi Pro's Avatar
Trade: Painting / Decorative Concrete
Hey guys need some help... Finishing up exterior repaint & owners also have asked if we could do there pool deck. It's your standard pool decking concrete. I was told it was painted about a year or so ago, but I don't know the product that was used, meaning stain or paint and owners don't know what was used. Decks not in horrible shape but in that amount of time I would think it should not look as bad as it does. Color is a light yellow cream. Any suggestions on what type of products to use. We will definitely pressure wash with a bleach soultion first.
Thanks in advance!
Guardi Pro is offline
Old 04-16-2006, 01:31 PM   #2
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Re: Need Help: Painting Pool Deck
You really need to find out what's on that deck first. If it's latex, you can take a rag with denatured alcohol and rub it. If it comes up on the rag, it's most likely latex. Is it chalky on the surface? If so, it could be an epoxy (not likely). Or it could be an oil based product.
When I'm in doubt, I'll sand down the surface thoroughly to provide good tooth, then topcoat it with SW's ArmorSeal 1K waterborne polyurethane and I usually get good results.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 04-16-2006, 02:44 PM   #3
1Painter's Avatar
Trade: House Painter
Hope the previous painerts ecthed the concrete, if not there is a big problem in the future. Just my $.02
1Painter is offline
Old 04-16-2006, 08:31 PM   #4
Guardi Pro's Avatar
Thanks for the advise AA... The surface does not seem chalky. Will try the D alcohol and see what happens. I know we need to find out what's on the deck, but that's easier said than done.
Old 04-16-2006, 08:55 PM   #5
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Depending on how bad the existing coating is, you may want to try to strip it off, rather than rely on it as an underlayment for your coating. I get real freaked when I have no faith in the previous coats.
Try a random adhesion test on it somewhere it isn't already peeling.
Cut an X with a utility knife, and apply some masking tape to it. let sit a couple minutes, and yank it off. If any paint comes with it, its adhesion is in question.
ProWallGuy is offline
Old 04-16-2006, 09:01 PM   #6
Guardi Pro's Avatar
Thanks Pro Wall Guy...I do not like getting into situations like this, but being we are doing there exterior I would like to help them out on the deck plus this was also a refferal...
Old 04-17-2006, 08:48 AM   #7
Pro Painter
AAPaint's Avatar
Oh yeah....forgot the condition part. If it's in ratty condition it may have to come up completely and start from new. That's what I like about this place...leave something out, and somebody will always fill the gap with info!
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 04-17-2006, 08:48 PM   #8
Guardi Pro's Avatar
AA... Used the D alcohol and paint did come up with little effort, so I would assume Latex was used. We tried SW Super Paint for the first time on the exterior and I would have to say; would definitly use again... I think the best thing to do for the deck is use a stripping tip when we pressure wash and then try the product you recommened from SW. Prowall... Used the razor knife and tape looked pretty good when pulled up. *** The deck also as quite a few cracks not very deep, but long some 6" to 23" any suggestions on what to fill with. CON SEAL from SW ??? Thanks guys!
Old 04-17-2006, 10:04 PM   #9
Pro Painter
AAPaint's Avatar
Hmm...don't foret one more important factor...slip resistance. The armor seal is a pretty slick product, and I'm not positive about adding abrasive to it. I'd check with a rep to see about adding some sand to it for grip...It's normally a commercial/industrial floor coating. It is super duty stuff, but like I said, it's kinda slick. I've never used it on a pool deck or anything, but it gives a nice finish for sure.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
to tie deck or not POOLMANinCT Pool Construction & Enclosures 22 03-10-2007 08:40 AM
Painting a Pool plazaman Painting & Finish Work 7 01-09-2007 12:26 AM
warranty for painting a deck in chicago gjs Painting & Finish Work 6 06-09-2006 07:28 AM
painting wood deck pauls painting Painting & Finish Work 16 12-14-2005 01:04 PM
