Need help spraying doors
Question about spraying doors -
I finally upgraded to a titan advantage from a little graco handheld that I used for the occasional door or two and so im doing these doors (recoat), prepped them by filling in any dings, lightly sanding with fine grain, dusting, then sprayed them, but I'm getting these little micro bubbles in the paint! So I let it dry, sanded them again, dusted, turned down the pressure some more, and the bubbles were still there! I'm not sure what's up. The tip is brand new. I'm sure it's user error, since I have limited experience with these bigger pumps.
Im using a 310 RAC X FFT, devoe something something semi-gloss, Titan Advantage, graco contractor gun. Is it a pressure thing or am I totally off the mark?
I'm at a loss and I have 10+ doors and tons of trim to do, so I'd really appreciate any help/pointers/etc. Thanks.
