Need An Airless Paint Sprayer For Cabinets
Old 04-05-2010, 07:27 PM   #1
hy_tek's Avatar
Trade: Electrician
I need a paint sprayer so I can redo some cabinets with primer and then paint them. I read that the Wagner Airless type sprayers don't work well or not at all. They clog up too easily and are just a headache. Is there a paint sprayer out there that is decent for the home projects and yet doesn't break the bank? Some said to go with the smaller Grado units but I know nothing about sprayers.
I do have an air compressor but I read that those types of cannister air sprayers make a terrible overspray for fine work. Help out a fellow who know nothing about sprayers.
hy_tek is offline
Old 04-05-2010, 08:37 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Self Employed Moron
Rewards Points: 4,302
Re: Need An Airless Paint Sprayer For Cabinets
Airless or Air Assisted Airless sprayers are professional equipment. Unless you can find a steal on a used one, you aren't gonna get one of these units on a budget. A siphon gun will produce a good amount of overspray. A HVLP gun will do a lot better, but probably won't do well with latex or oils because they will need ot be thinned to much to be atomized properly.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 04-05-2010, 09:02 PM   #3
BC_Painter's Avatar
Trade: Painting Contractor
Rewards Points: 25
It really depends how often you plan on using the sprayer.
The small gracos are great, small titans are great too. Don't get the ones from Big Box stores, they are not worth their weight and not worth repairing once they break.
Getting a used sprayer is the best bang for your buck but if you keep your eye out for sales, a new graco 390 will last you pretty well forever when properly maintained
BC_Painter is offline
Old 04-05-2010, 09:21 PM   #4
BuildersII's Avatar
Trade: General
Rewards Points: 250
If you're just doing the one job, you can rent some pretty nice equipment without losing your shirt. Don't kid yourself, you will have to mask off the entire room, seal it off from the rest of the house, and preferably set up some negative airflow with a fan blowing out of a window.
BuildersII is offline
The Following User Says Thank You to BuildersII For This Useful Post:
BC_Painter (04-05-2010)
Old 04-10-2010, 01:57 PM   #5
Rcon's Avatar
Trade: wood finishing
Rewards Points: 75
I wouldn't be spraying any cabinets on your first attempt at using a sprayer, unless they're your own
That said, check your local classified ads for used airless equipment. Look out for anything graco (390, 395, 490, 495), small spraytechs are alright, or you can get a DIY titan sprayer from HD for about $300 which works OK.
Alec
Rcon is offline
Old 04-10-2010, 09:56 PM   #6
abacab's Avatar
Rewards Points: 390
I have a wagner sprayer, paid about 300 about 10 years ago. It has served me well, even for fixing the mistakes of the painters $3000 unit. I'm now doing more volume and find that it can't keep up for latex and doing entire houses. I find it works best for cabinets, polyurethanes, and small additions. Makes sure you use the right size spray tip.
abacab is offline
The Following User Says Thank You to abacab For This Useful Post:
hy_tek (04-11-2010)
Old 04-11-2010, 09:27 AM   #7
hy_tek's Avatar
Trade: Electrician
Ok if one was to buy a Wagner sprayer which one would be the best? I see there is a newer hand held power plus unit that seems to put out more pressure than the other Wagner canister sprayers. I will probably never use it again after painting these couple cabinets so I hate to blow a bundle of cash when something smaller could get me by. Renting a huge sprayer seems like overkill for this small project.
hy_tek is offline
Old 04-11-2010, 09:29 AM   #8
Andrew M.'s Avatar
Rewards Points: 150
We need to know what you are spraying? LAQ., Oil or latex?
Andrew M. is offline
Old 04-11-2010, 12:19 PM   #9
hy_tek's Avatar
Trade: Electrician
I am spraying a couple wall cabinets in my laundry room. I am using latex primer and latex paint. Sorry I just assumed now a days every one used latex for interior paint work. Should have been more clear.
hy_tek is offline
Old 04-11-2010, 12:33 PM   #10
Andrew M.'s Avatar
Rewards Points: 150
HVLP would be hard to do unless you have an expensive unit. Airless will make a huge mess, you have to watch all the overspray, gets everywhere, but it can be done. Do not expect it to look like an oil/LAQ based job with Latex. The primer has to be smooth. Water base raises the grain so you need to sand after the primer, tack cloth surfaces.
Gleempaint.com might have some recon units. New, the best deal is an older graco 190es that is fine for limited use. $500 over the web.
I have used the fine foam mini rollers and they will give good results on flat surfaces,slight orange peal, I add Floetrol for leveling, either method.
Honestly , latex is not a good choice unless these are utility use cabs. I would never do that on Kitchen cabs.
Old 04-11-2010, 12:58 PM   #11
hy_tek's Avatar
Trade: Electrician
They are old dark cabinets on the wall in my laundry room that I need to make white. I don't have to use latex paint I just thought it would be more user friendly is all.
hy_tek is offline
Old 04-12-2010, 03:16 PM   #12
Andrew M.'s Avatar
Rewards Points: 150
The mini foam roller might be an option if they have basically flat doors. On latex they do about the same as a sprayer.
Old 04-12-2010, 03:38 PM   #13
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Rewards Points: 256
I agree with the foam roller, especially for a laundry room at my own house
BACKWOODS is offline
Old 04-13-2010, 01:38 AM   #14
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,292
get a painter to spray out your cabinets.
Metro M & L is offline
Old 04-13-2010, 06:25 AM   #15
KJames's Avatar
Trade: Painting/Renovations
I wouldn't use a foam roller if your looking for quality. I have a graco 4900 HVLP (High volume low pressure) fine finish sprayer. Thats what I would use. Try renting one. Mine sprays latex (check that before you rent). The HVLP has very little overspray compared to an airless. And when you spray, less paint, more air for a finer finish. If you were going to roll, as opposed to foam, try a 5ml roller - i think you'll get better results.
KJames is offline
Old 04-14-2010, 07:28 PM   #16
Kevin M.'s Avatar
Rewards Points: 2,164
Hy tek,
R con turned me on to a product called Cabinet coat. I just did a kitchen using the Cabinet coat applied with a whizz flock roller. It seriously looks like a spray finish without the hassle. This stuff is pretty much bullet proof. It dried overnight hard as a rock, (real durable)
It's way more user friendly than spraying with real good results.
BTW....
Alec is brilliant!!!
Need an airless paint sprayer for cabinets-004.jpg   Need an airless paint sprayer for cabinets-005.jpg
Last edited by Kevin M.; 04-15-2010 at 10:40 PM. Reason: Deleted smiley to clarify compliment
Kevin M. is offline
Old 04-15-2010, 03:10 AM   #17
Rcon's Avatar
Rewards Points: 75
Alec
Rcon is offline
Old 04-15-2010, 06:10 PM   #18
gambynh's Avatar
Originally Posted by Kevin M. View Post
Hy tek,
BTW....
Alec is brilliant.
Cabinet coat is good stuff. I keep a supply of it in popular white/off white colors.
gambynh is offline
Old 04-15-2010, 07:03 PM   #19
hy_tek's Avatar
Trade: Electrician
I've never seen that Cabinet Coat at the hardware store. Is this a special order item or would they have it at Menards or Home Depot?
hy_tek is offline
Old 04-15-2010, 08:01 PM   #20
Kent Whitten's Avatar
Rewards Points: 2,040
http://stainmasterpaint.com/viewProd.asp?prodID=180
click on "find a dealer"
SalmonFallsCabinetry.com
Kent Whitten is offline
Paint or stick with solid color stain? JL1 Painting & Finish Work 46 01-16-2014 06:58 AM
Paint Shaver vs Infrared Paint Removers Goochie Painting & Finish Work 12 09-11-2012 05:05 PM
Inexpensive sprayer for a ceiling roof-lover Painting & Finish Work 6 01-22-2009 07:41 PM
Paint Sprayers BiggersJunior Painting & Finish Work 27 01-12-2009 09:49 PM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
