Need Advice! Staining Concrete With Border
Old 10-28-2007, 11:06 AM   #1
Guardi Pro's Avatar
Trade: Painting / Decorative Concrete
Exclamation
Have a concrete driveway with a walkway to front door. Need to do 4 inch SOLID border around driveway. Colors are (TBD) but only working with 2. Base color for drive / walk way & border color. (My concern is the border, can't have any bleed thru). How would you handle doing the border??? Tape? Stencil? Roll/Brush or HVLP.
We will use a de-greaser then use H&C Acid etching solution. Would you also use H&C Stain?? Worried about Hot tire pick up.... Can there products stand up. Thanks for any advise you guys can give!
Guardi Pro is offline
Old 10-29-2007, 07:55 AM   #2
Guardi Pro's Avatar
Re: Need Advice! Staining Concrete With Border
can Anyone One Offer Any Help ???? Come On Guys. Thank You
Old 10-29-2007, 02:23 PM   #3
Painting Contractor
JMGP's Avatar
I would use a quality duct tape for border..... press it down firmly....
JMGP is offline
Old 10-29-2007, 08:31 PM   #4
CaliDesigns's Avatar
If you are using an acid stain, you have to put a saw cut in the concrete at least a 1/2" deep. Acid stain will penetrate at least 1/4" . Tape won't do squat!
CaliDesigns is offline
Old 10-29-2007, 08:39 PM   #5
Guardi Pro's Avatar
Calidesigns: No i'm not using Acid Stain. Looking at using H&C water based Stains. Would you use a high adhesive tape?
Old 10-30-2007, 12:20 AM   #6
You said in your first post "H&C acid etching solution". Water based stain is a glorified word for paint in my opinion. If you have any water migration through your concrete, it will delaminate. Been there, done that, never do it again. I don't like disappointing my clients and I cherish my reputation.
Old 10-30-2007, 03:04 PM   #7
aceflooring's Avatar
Trade: Flooring, Concrete Stamping, Staining, Overlays, & Remodelings
Acid stains are awsome!!!
Need advice! Staining concrete with Border-thin-20stained-20overlay-20familyroom3.jpg
aceflooring is offline
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Need flooring advice sparkysteve Flooring 9 09-22-2007 03:12 PM
Advice needed - border installation tim790 Flooring 5 07-11-2007 09:24 PM
Problem with customer.. need advice 6stringmason General Discussion 32 01-15-2007 08:48 PM
