Trade: Painter
Nap Size Most Used
Hi Guys. I am new the group and new to painting. I have been painting for a living for the last 8 months. I have 100's of questions...a lot of them have been answered by reviewing the information that has been provided by group members. Thanks.
Questions for you. What nap size do you commonly use for flat surfaces, latex paint, interior work? I usally use 1/2 inch. I have tried 3/4 but it leaves too much of an orange peel effect. Any of you use 3/8?? Do you find a difference between more expensive roller sleeves vs. cheaper ones?? |
Back from the dead...
Trade: Paperhanger/Painter
Re: Nap Size Most Used
We use 3/4" almost exclusively.
The Wooster 50/50's leave a small stipple, but spreads out nicely. Anything under a 3/4" and you are dipping for paint more than twice as often. |
Pro Painter
I usually base the nap on the type of paint. For something thin and silky like duration, I use a 1/2".....Like PWG said though, sometimes it will leave ya dippin alot..However, if you DUNK the roller, spin it once or twice on the grid, then sling it on the wall, a 1/2" will work just fine. The only time in these cases I would use a 3/4" is on 9' plus high walls cause ya can't get enough for a whole strip on the wall, 3/4 is the only thing that will hold enough to do high walls.
Aggree with the others--I was using 3/8 for "smooth surfaces" then woke one day up after dipping every three seconds. 1/2 is my standard. 3/4 occasionally.
Richie |
...jammin
Trade: Rock Disciple
Mostly 1/2
Sometimes 3/4 Absolutely the better quality sleeves make a big difference Yes they are usually more expensive I always have some "throw-away" sleeves on hand, but I really don't like using them In a case where I don't want to wet a new sleeve, I'll use a good one that's been cleaned a few times rather than a cheapo |
| What size Staple for # 8/3 ? | davidchomes | Electrical | 16 | 08-21-2007 06:06 PM |
| What size pressure washer and tip do I clean a deck with? | jimb317 | Painting & Finish Work | 11 | 07-02-2007 01:43 AM |
| What size roller covers? | metomeya | Painting & Finish Work | 10 | 11-28-2006 06:48 AM |
| size of your crews on a job | scottstef | Painting & Finish Work | 13 | 10-17-2006 01:21 PM |
| Header Size | TriadMaint | Framing | 9 | 04-01-2006 08:18 AM |
