Nail Hole Issue.. Any Suggestions?
Old 10-25-2007, 06:31 PM   #1
Jbrad4d_iv's Avatar
When I fill nail holes on trim, I usually use DAP Painters Putty. I find that after how ever many coats of paint I put on, I can still see a little divet from where the holes were filled. I have used wood filler then sanded flush. I was just wondering if anyone has any suggestions or products that they use that they find better and more helpful. Thank you!
Jbrad4d_iv is offline
Old 10-25-2007, 06:48 PM   #2
Re: Nail Hole Issue.. Any Suggestions?
I like DAP "Fast 'N Fill". Red Devil makes something like it. If the tub feels empty when you pick it up? That's the stuff! It actually swells a bit when it dries, and you can sand it smooth.
neolitic is offline
Old 10-25-2007, 07:22 PM   #3
DeanV's Avatar
Trade: Painter
I actually like the hard to sand putty. If you pack the hole full, there will be no dimple when it dries. With the hard putty, you do not have to worry about sanding it below flush either. Of course, it is more work to sand, but if you pack it just right so a little extra is above the nail hole, it is not too bad.
DeanV is offline
Old 10-25-2007, 07:24 PM   #4
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
I like Drydex
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 10-25-2007, 07:32 PM   #5
jackrabbit5's Avatar
Trade: Paperhanger/painting contractor
I've used different lightweight spackles, and they do indeed seem to swell after filling, but they also sand down so easily that you seem to get the divits anyway. Then theres the fact that they are so porous that the paint "burns out" and you need several coats to get an even sheen. Lately I've tried the woodtoned latex wood fillers like Minwax. It takes longer to apply and more work to sand down, but I get better end results.
Stacy
S B Bolson & Sons
jackrabbit5 is offline
Old 10-25-2007, 07:34 PM   #6
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
There's really only one product that is above the rest...
Durham's Rock Hard Water Putty. I use the tin top of the can to mix up small batches with a putty knife. Then I use my finger or putty knife to fill in holes in trim etc. It dries rock hard in 20 minutes. Only need to hit lightly with some sandpaper. It'll come out smooth. Can be used prior to priming as it won't shrink. Available at HD / Lowes / lumber yards.
I can't yet post a url so search for website or images of the product.
We Fix Houses is offline
Old 10-25-2007, 08:15 PM   #7
Jbrad4d_iv's Avatar
Wow thanks a lot, I really appreciate all of your tips. I am absolutely going to try your ideas out.
Old 10-25-2007, 08:50 PM   #8
Workaholic's Avatar
Trade: Painting Contractor
I use Crawfords.
I too keep some rock hard on the van.
Sean
Workaholic is offline
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 09:14 PM
Looking for the absolute best nail hole filler Dorman Painting Painting & Finish Work 19 10-28-2007 02:23 PM
Nail holes and cleaning Tom M Finish Carpentry 7 06-16-2007 09:43 PM
Back panel hole england030 Carpentry 2 05-18-2007 10:05 PM
