Multispec Spraying??
Old 04-08-2008, 09:46 AM   #1
BMAN's Avatar
Trade: Painting & Remodeling
Rewards Points: 250
Anyone have any experience with multi spec and want to give some advice? What is the best rig for spraying it?
BMAN is offline
Old 04-08-2008, 04:56 PM   #2
Painting Contractor
JMGP's Avatar
Rewards Points: 250
Re: Multispec Spraying??
You need to use an HVLP... preferably using the pressure pot and finish gun... not the cup... I dont remember what size tip... I want to say 2 but I am not 100% sure... You will have to do a few test runs to get it to where it works for you...
JMGP is offline
Old 04-08-2008, 05:50 PM   #3
Al Truistic's Avatar
Rewards Points: 135
It can be sprayed with an airless! Just pull all your filters, fairly large tip, and when you think you have good coverage, paint some more, that stuff really shrinks.
But I agree that an hvlp and pressure pot is the preferred way to go.
Al Truistic is offline
Old 04-08-2008, 07:23 PM   #4
plazaman's Avatar
Rewards Points: 1,202
what exactly is this stuff? Purpose?
plazaman is offline
Old 04-08-2008, 07:28 PM   #5
98mustangguy's Avatar
Trade: Home Improvement
Rewards Points: 75
Watch your pressure if it is too high your multi spec will spyder web out. I would also suggest an inline pas through style pressure gauge on your airless that way if you dont finish job in a day or have to touch up you can set to exact pressure you previously used. Multi spec is a talent to spray properly many people dont do such a great job with it.
98mustangguy is offline
Old 04-08-2008, 07:31 PM   #6
Rewards Points: 75
Its a type of industrial paint, you see it quite often in like doctor offices and such. usually whitish paint with like red,blue,black specs in it about the size of a pencil point. Just an expensive decorative paint instead of the usual flat 1 color paint
Old 04-08-2008, 08:03 PM   #7
Painting Contractor
JMGP's Avatar
Rewards Points: 250
There are different types of Muti Spec... I believe the ONLY one that you can use an airless with is called Multi Spec / Fine Fleck....
DO NOT USE an airless for any other type of Muti Spec...
There is A LOT to learn about Multi Spec it is not the same as conventional spraying you may be used to doing where you just plop the sprayer into a bucket and go for it... There are many options... many applications...
It has been awhile since I have done a Mutli Spec project but I have done a handful of them and I only know bits of info that I can remember...
I suggest doing some other forms of research to get more in depth info on it...
JMGP is offline
Old 04-08-2008, 08:44 PM   #8
ibsocal's Avatar
Trade: Pain
Rewards Points: 160
do not mix it agresivley.m i x i t g e n t l e y.spray it hvlp turbine biggest projector set, v e r t i c a l & h o r i z a n t a l pass patterns.dont pay more than 50 bucks a gallon.dont over pressurize or u will get tails.apply clear coat to areas that will get a lot of use and abuse.thats my two pesos.
ibsocal is offline
Old 04-10-2008, 05:01 AM   #9
Professional Remodeler
firemike's Avatar
Rewards Points: 1,000
I use a 2 gallon peressure pot and gun. My dealer had special tips for the those type of paints. Back when Aqua-Flek was still around, thay had a low pressure fan pattern tip for conventional guns that sprayed a nice wide, flat pattern (Aqua-Flek has some products that had rather large particles in them) still works great for the Multi-Spec's products too. At approx 18" from the wall it sprays a pattern about 1" to 2" wide by 14" to 16" tall.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 08-23-2008, 06:59 AM   #10
Traditions2's Avatar
Trade: painting and refinishing
Rewards Points: 150
anyone ever heard of using mutlispec on a floor then clearing it?
Traditions2 is offline
Old 08-23-2008, 11:24 AM   #11
General Contractor
Snow Man's Avatar
Trade: Construction Management
Multi-spec is a beautiful oil/latex base finish. Yes, both oil and water paint based material spray only.
Excellent institutional / commercial corridor finish for schools ,offices etc..
I did a ton of it a few years back . Very expensive material. Drys like a rock. Many , many 2,3 and even 4 colors at one shot. I see that they make a water base only material too. It's been a while.
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 08-23-2008, 04:46 PM   #12
Rewards Points: 150
so it'd work on flooring? I used some multistone from midwest chem. and it worked great. They say it can be used on floors. I was just curious if sherwins multispec was comparable.
Old 07-16-2011, 01:17 PM   #13
ramassini's Avatar
Trade: ramassini painting inc.
Talking
best way and equipment to use is as follows;
1. Binks 2100 gun.
2. 68 ss fluid tip.
3. 68 22 air nozzel.
4. 568 needle.
5. Dual regulater 2.5 gallon pressure pot.
6. 3 to 5 horse power, 25 gallon air compressor.
7. Fluid pressure 45 to 55 psi.
8. Air pressure 40 to 50 lbs.
Adjust fluid and air as needed. Cross hatch method is best with 20 to 24 inch distance from spray area.
More air pressure smaller the particles. Less air larger the particles.
Have fun.
ramassini is offline
Old 07-20-2011, 05:41 PM   #14
AdvancedRes's Avatar
Trade: Restoration
I agree with post #1 , use a pressure pot *best*.....I did apply it with an HVLP and large cup gun with a #3 tip......It was not too far off from the product supplied sample the customer had , However it was off and not exact. The only thing that saved me was that the owner of my company had set it up so that he would not guarantee an exact match. I think we could have gotten it closer had we used a pressure pot. She was very happy anyway. I made long light sweeps , let it set up a little , then went over it medium/heavy.....the work was in all the masking.
AdvancedRes is offline
Old 07-21-2011, 05:03 PM   #15
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Rewards Points: 286
Send a message via AIM to MarvinWilleyJr
I used it 15 years ago or so... I went one way on a hall with a new hvlp, and another guy started in the other direction with a binks gun and pot. When we met up around the building mine matched the sample and his was way off. The binks gun broke up the particles way too much, but the hvlp layed them on more evenly. The Binks gun was faster, but depends on which your wanting.
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
MarvinWilleyJr is offline
Old 05-19-2017, 01:04 PM   #16
harmonpa's Avatar
Rewards Points: 30
Binks actually has an outfit with a pressure pot and 2100 spray gun designed for it. The 2100 spray gun is a 66ss with a 200 air cap. If you need a pressure pot with it the setup would be a 98c-359. This set up is designed for multi spec paints like zolatone ect the pressure pot is dual regulated and has air and fluid hose.
harmonpa is offline
Old 05-19-2017, 08:45 PM   #17
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Since we are reviving this thread, here's my 2 cents:
I use a Titan Capsray 75 HVLP (use it mainly for tub epoxy, ,but works great for multi spec)
I use the factory setup, some say go big on the needle, but in my experience there's no real need. I have tried larger needles, same result.
I use the 3m PPS system, so make sure to remove the liner lid filter.
Turn the air knob down, volume knob out all the way and stand back as far as you can and let it rain. Make sure to mask to accommodate this. 12" brown paper is not enough. I use 48" hand masking film.
It an "artsy" paint. So I do samples on drywall. You can go with a light pattern and let the primer bleed through on purpose, which will drastically alter the outcome. Or you can go heavy and hide the primer. Play around with different colored primers, and let them bleed through. You can literally create your own unique color schemes that no on else has.
But definitely do a sample and get approval first. Sometimes I will ask the homeowner to stand next to me and watch so they can be more involved in the final outcome. I'll see if I can dig up examples of the bleed through I am talking about.
www.callbathdoctor.com
Driftweed is offline
Old 05-19-2017, 08:59 PM   #18
Accidental Painter
Driftweed's Avatar
Here we go. 1st pic is before, 2nd is primered black, 3rd is finished. and 4th is an idea of the masking.
That was a white multispec with grey dots (Galaxy, i think) and they let me get artsy. Customer wanted something to contrast all the white cabinetry, hence letting the black primer bleed through.
Multispec Spraying??-20160425_110536_resized.jpg   Multispec Spraying??-20160425_132258_resized.jpg   Multispec Spraying??-20160425_155055_resized.jpg   Multispec Spraying??-20160425_135212_resized.jpg
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 14 05-26-2017 12:58 PM
Spraying pressure, tips and mostly technique bgpainter Painting & Finish Work 11 08-12-2008 10:39 PM
spraying has ruined my brush and roll estimating Traditions Painting & Finish Work 11 09-15-2006 03:31 PM
spraying on stilts!!!!! drywall Drywall 5 07-06-2006 10:51 PM
Spraying varnish? BChester Painting & Finish Work 1 10-26-2005 08:28 PM
