Multi Purpose White Paint For Warehouse
Old 09-01-2017, 03:52 PM   #1
ragadozo's Avatar
Trade: Commercial Framing
Rewards Points: 26
Question
I recently received an offer to bid on a warehouse remodel. The client basically wants a few partition walls put up and wants the current untreated block wall/drywall to be painted white. The block walls are not exterior but demising walls separating the warehouse unit from the adjacent ones. There are two block walls at each length of the unit. (rectangular) So I dont assume they are holding water.
I was wondering if it would be better to use a multi purpose primer/sealer since I dont know how efficient it would be to be getting drywall specific and block wall specific paints & primers and to keep having to switch buckets with the sprayer. It needs to be white but it doesnt have to have 'show room' quality finish. Is a block filler absolutely necessary? Or would a regular all purpose primer/sealer work? I am assuming exterior only, or would interior suffice?
One caveat is that one area of the warehouse will be used as a wash area that will be waterproofed up to about 10ft but past that height I am wondering if I need to use a different paint or exterior paint?
ragadozo is offline
Old 09-01-2017, 08:07 PM   #2
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,412
Re: Multi Purpose White Paint For Warehouse
If block walls are bare then I would prime with block filler. For new drywall I would use a drywall primer. I would then paint all the walls with two coats of Multi Surface Acrylic. The MSA has to be sprayed, it is not so good for brush and roller.
Best thing about MSA is it is dryfall too. MSA is an exterior paint but I would have no problem using it in a warehouse type environment. You can get it in eggshell finish.
Hope this helps.
Ohio painter is offline
Old 09-01-2017, 08:10 PM   #3
You asked if block filler necessary, I think if you want a decent looking finish then yes. Plus it is about the cheapest primer you can get. I think block walls without it look like cr@p.
Old 09-08-2017, 09:21 AM   #4
Fishindude's Avatar
Trade: Industrial
Rewards Points: 396
Not uncommon for us to spray an entire warehouse; ceiling, structure, upper walls, etc. with a white dryfall material. This is fast and although we lay down plastic in work areas, most of the overspray drys before it hits floor and can be swept up.
Then we finish paint (brush & roller) the lower 10', doors, etc. with a semi-gloss material that can be cleaned, doesn't show hand prints, etc.
Fishindude is offline
Old 09-28-2017, 09:35 PM   #5
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
Block fill the block walls. It's inexpensive, and you'll end up with a nicer finish for a commercial building. Multi Surface is a good suggestion. And you can roll it if you didn't want to drag the sprayer out. Or you could try SW Sher Cryl for the wash room areas. That has great chemical resistance and will hold up to many cleaners.
DiaperRiot is offline
white on white.. tylerdean Painting & Finish Work 39 03-22-2016 10:13 AM
Best paint / advice for aluminum siding? Jdub2083 Painting & Finish Work 15 07-12-2012 01:15 AM
Making a Dollhouse Bookcase. Suggestions on paint type and finishing... rdr8887 Painting & Finish Work 9 06-24-2012 10:37 PM
White Paint and the Taser...haha GPI Painting & Finish Work 4 09-30-2010 12:24 AM
Satin Paint vs. Stain on Rough Cedar Siding Biker01 Painting & Finish Work 4 09-21-2010 11:18 PM
