Mixing Your Own "safety" Paint
Old 07-10-2005, 11:37 PM   #1
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
OK painter friends...a question:
I need to mix paint and "sand" together for safety purposes. I know I can buy this stuff pre-mixed, but I have about a ton of sand sitting in the back without a home , and I also have means to screen out anything to big to mix into paint...SO:
Anyone have any idea how much per gallon, and what size "sand" is usually used for this?
jproffer is offline
Old 07-10-2005, 11:42 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Mixing Your Own "safety" Paint
I honestly don't know if the type you buy to add to paint is any different from play sand or whatever. I'd do it.
How much? I usually start adding it to a paint setup (five gallon bucket), mix it good, and test drive it with a brush. When it looks thick enough, I paint away.
Remember, you can always add more, but you can't take it back out!
ProWallGuy is offline
Old 07-10-2005, 11:52 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
I did make my own for a boat project a while back
I really can't remember the ratio
It was play sand type, it might have been labeled "landscape sand" (?) but it was...pre-screened(?)...all the same size, or close anyway
I made several mixes, like PWG says (though I did gallons), and tried them before I got the ratio right
slickshift is offline
Old 07-11-2005, 11:19 AM   #4
Teetorbilt's Avatar
I have found that if you premix it tends to get streaks. I do it this way.
Make a sand shaker from a coffee can with nail holes punched in the bottom. Roll out some paint and shake the sand onto the wet paint. Let dry and come back with a lockdown coat. The end results are far superior to premix.
If you want to play around with textures, you can use glass beads, bubbles, Q-cells, different grades of sand or, for real serious jobs, ground walnut shells.
Albert Einstein
Teetorbilt is offline
Old 07-12-2005, 08:40 AM   #5
Dripless
Dale's Avatar
Trade: Painting and exterior wood care
If you're using your own sand I'd wash it first to get the dust off....or not.
I like Teedorbilt's idea for even application.
Dale is offline
Old 07-12-2005, 07:00 PM   #6
jproffer's Avatar
Thanks Dave, I thought the same thing, I already washed it....actually I washed it, sieved (screened) it, took out the sizes that I wanted, washed it again and sieved it again to get any little amount of dust that was left out. One of the advantages to working in a rock quarry QC dept.
Good idea Teetor about sprinkling after the first coat.
jproffer is offline
Old 07-12-2005, 07:47 PM   #7
ProWallGuy's Avatar
Hell, after all that, I would have went and bought some painters sand and called it a day!
Mixing and Matching Paint?? Jethroe Painting & Finish Work 6 05-22-2007 06:27 AM
mixing your own paint HUDSONVALLEYEXT Painting & Finish Work 23 04-16-2007 01:30 AM
mixing paint and stain design question???? MikeT Windows, Siding and Doors 2 08-25-2006 07:10 AM
