Metal Wall Panels For Decor As Wainscot
Old 03-31-2006, 12:38 PM   #1
pshammond's Avatar
Trade: painting contractor
Question
I am decorating a golf clubhouse with an airplane theme. My idea was to use corregated sheet metal as a wainscot. Can anyone help me with this? Has anyone done this before? Where can I buy the sheet metal? How do you install it? I've tried researching on the web and can't find anything. My project is in Los Angeles, CA. Thanks!!
pshammond is offline
Old 03-31-2006, 03:52 PM   #2
1Painter's Avatar
Trade: House Painter
Re: Metal Wall Panels For Decor As Wainscot
I have use corregated metal before. I had to order from lumber yard. but you being in LA, Kalifornia. Check metal supply warehouse it comes in different gauges. You want the thin gauge, easier to work. To cut the metal turn your cirgular saw blade backwards.Try PL-400 to secure to wall , use as few screws if possible to keep a clean look. Maybe one at top , middle and bottom. Hope that helps you.
1Painter is offline
Old 03-31-2006, 07:03 PM   #3
Teetorbilt's Avatar
You may want to check out this site. http://www.fordtri-motor.com/ for some ideas. The tri-motor was built out of corrugated material and it might be fun to duplicate the rivet sequence if you can find a close-up.
Albert Einstein
Teetorbilt is offline
Old 03-31-2006, 07:16 PM   #4
Guardi Pro's Avatar
Trade: Painting / Decorative Concrete
Teetor... If i get 1/2 the knowledge you have, I'll do just fine in this business Good idea.. I would think your best bet is at the lumber yard. Good luck!
Guardi Pro is offline
Old 03-31-2006, 10:05 PM   #5
...jammin
slickshift's Avatar
Trade: Rock Disciple
I used to like Cafe Grounded in Guilford Connecticut
Maybe you could contact them for pics or ideas
http://www.newhavenadvocate.com/gbas...?oid=oid:21341
I think it's actually a Quonset hut
slickshift is offline
Old 04-01-2006, 05:41 PM   #6
Woz the Painter's Avatar
Do you have any Lone Star Steakhouses in your area? I painted a couple in Chicagoland and they have corrugated galvanized as wainscot on the walls in dining area and bar. Hope this helps, good luck.
Woz the Painter is offline
Old 04-01-2006, 10:11 PM   #7
Tscarborough's Avatar
I did one wall in my office with it. It looks good and it is cheap and easy. I did it so I could hang stuff on it with magnets, though.
Tscarborough is online now
Old 04-02-2006, 12:40 AM   #8
pshammond's Avatar
That's exactly what I want to do except horizontally and up about 3 feet. What did you use, where did you get it and how did you put it up? THANKS SO MUCH!!!!!!!!!!!!!!!!!!
Old 04-02-2006, 12:41 AM   #9
pshammond's Avatar
THANK YOU TO EVERYONE WHO HAS REPLIED - I REALLY APPRECIATE IT!! Sheryl
Old 04-02-2006, 01:07 AM   #10
It is available anywhere, but I would caution that it is pretty delicate. If you want to use it in a high traffic area, get the thick stuff (roofing) and use the formed furring materials at a close spacing.
Old 04-02-2006, 11:00 PM   #11
zico's Avatar
Trade: painting, flooring, trim carpentry
I was wondering if the corrugated metal has a tendecy to oxidize and get dull? The picture looks great, bet you its easy to clean if you kids. Just wipe the little blithers finger smears right off!
Halton Peel Painters
GTA Painters
...there's still fight in this dog
zico is offline
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
I goofed- how do I remove solder from wall panels? Dustball Plumbing 12 05-04-2007 10:40 AM
Metal stud wall and door frame ? MinConst Construction 8 10-28-2005 01:22 AM
