Metal Railing Finish Failed Problem?
Old 06-04-2006, 10:39 PM   #1
a68cudas's Avatar
Trade: pressure washing deck restoration
doing a deck for some lady got talked into doing the railing also which i normally wouldnt do since im not a painter its not my field of expetise. stripped old finish all way down applied acylic primer and 100% acrylic paint tiny rust spots started to bleed out but other than that the finish coat stuck good. so i put killz latex 2 coats and then 2 coats of same olympic 100% acrylic paint. was 90 degrees out that day by the time i got done doing one railing the primer was dried when i started the other one. and same thing with applying the acrylic paint. a day later rain and been raining. now i know i didnt miss any spots to let water or moisture soak in and the finish is failing all way down the horizontals tiny little blister bubbles all over it. what and how can i fix this? what would have made the finish fail? could something from the kills bled out cause was so humid out and hot that day? can i sand out the blisters and repaint? should i stick with the acylic or put on and oil based paint over the acylic? i need some advice from a pro painter. please help greatly appreciated.
a68cudas is offline
Old 06-04-2006, 10:44 PM   #2
Doing what I do.
fastg60's Avatar
Trade: Remodeling contractor/US Army
Send a message via AIM to fastg60
Re: Metal Railing Finish Failed Problem?
i would have hit the whole thing with some rust-mort, or por-15. both of these products will adhere to and stop any rust, leaving you a paintable surface with no rust problems...
fastg60 is offline
Old 06-04-2006, 10:45 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Acrylic primer wasn't a good choice for this application. And Kilz latex is just plain crap. Strip off the paint, and apply a high-quality oil/alkyd metal primer, like this one.
Top coat with an exterior oil finish or DTM acrylic.
ProWallGuy is offline
Old 06-04-2006, 11:33 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
All of the above ^^^
Rather than POR as fastg60 says, I prefer Eastwood Co.'s Rust Encapsulator as it does not need top coating
That may be a bit much if it's a little cheap project
The BM metal primer etc. may be a better choice for this one
slickshift is offline
Old 06-04-2006, 11:34 PM   #5
...jammin
slickshift's Avatar
POST OF THE DAY!!!
Old 06-05-2006, 12:58 AM   #6
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Originally Posted by slickshift
POST OF THE DAY!!!
Ok, I see what's going on here.....will you two stop telling each other "post of the day"?? LoL!!
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 06-05-2006, 05:11 PM   #7
Dave Mac's Avatar
Hammerite is my favorite product for iron rail, i have had very good results with it,
Dave Mac is offline
Old 06-05-2006, 07:24 PM   #8
Teetorbilt's Avatar
Strip, kill the rust with Ospho, scratch with a green 3M pad and use an oil based paint like Rustoleum. Problem solved.
Albert Einstein
Teetorbilt is offline
Old 06-05-2006, 09:19 PM   #9
KellyPainting's Avatar
Latex primer has water in it... your aplying water to metal to start with
.. bad combination.... Oil primer is the only way to go. and if it's a small railing why paint? Just buy a few cans of rustoleum?
reprep first...
KellyPainting is offline
Old 06-06-2006, 03:37 AM   #10
King of Caulk
asbestos's Avatar
Trade: If you wanted it done by a professional, why did you call me?
This wasn't a galvanized railing that had rusted in some spots was it?
PS KILLZ= $15 a gallon at wal-mart that says it all
You want absolutely security? You want to be totally protected against terrorism? I have a proposal for you: A one way ticket to Panmunjom in North Korea. Guarantee you, they have absolute security. You will have absolute protection against terrorism. There is no terrorism in North Korea except the terrorism, of course, that is wielded by the state itself. Because there is no privacy, there are no constitutional rights, there is no freedom. But you've got security.
Ted Koppel
asbestos is offline
Metal Roofing question? fullhouse Roofing 9 07-01-2011 10:32 AM
Finish Nailing Problem mms Finish Carpentry 8 03-29-2007 10:40 AM
Installing metal roofing over metal roofing bugdoc@linkny.com Roofing 3 04-04-2006 08:48 PM
Problem with metal roof/gutters Teetorbilt Roofing 19 12-09-2005 10:57 AM
Metal Studs???? ARKFRAMER Carpentry 36 04-10-2005 12:48 AM
