Melanine Finish
Old 12-27-2008, 10:38 PM   #1
profesional handyman
winn's Avatar
Trade: professional handyman services
Send a message via AIM to winn
Melanine Finish
need to finish some poplar doors to match the melanine carcasses. we are replacing the doors and want to leave the carcasses alone. color is not the problem its the finish
winn is offline
Old 12-31-2008, 05:45 PM   #2
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
Re: Melanine Finish
good luck,
poplar is more of a paint grade than stain grade wood. it is very hard and does not take stain well.
your best bet is to play around with one side of one door till you got it down and then install that particular side in an inconspicuous spot, like the inside of a closet door-side.
vandyandsons is offline
Old 12-31-2008, 05:51 PM   #3
Handle It!
MALCO.New.York's Avatar
Re: Melanine Finish
Melanine??? What is it?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 12-31-2008, 06:05 PM   #4
Motorboatin' son of a ...
BKFranks's Avatar
Re: Melanine Finish
I think he means melamine. It's a plastic coating that cabinets are made out of. They take particle board and coat it with a plastic. Comes in different colors. Most of the time cabinets are made out of the white.
BKFranks is offline
Old 12-31-2008, 06:08 PM   #5
Handle It!
Re: Melanine Finish
I know what it is. I just do not think that the OP, having misspelled it, knows the nature of the beast!
Old 12-31-2008, 06:26 PM   #6
BKFranks's Avatar
Re: Melanine Finish
Why not just order some thermofoil doors to match?
BKFranks is offline
Old 01-01-2009, 10:09 PM   #7
Painting Contractor
Damon T's Avatar
Re: Melanine Finish
assuming it's paint grade, and not a fake wood look, go with a high build oil or a shellac primer, spray the doors flat. Apply at least two coats, sanding in between coats with 150 grit or so. spray two or more coats of appropriate sheen enamel, typically high gloss. see other threads for painting cabinet details.
Damon T is offline
Old 01-09-2009, 10:51 AM   #8
winn's Avatar
Re: Melanine Finish
primed with zinnzer 123 finished with behr satin latex. had the color computer matched. sprayed half of one of the old melanine drawer fronts and nobody could tell which side had been sprayed. used a small piston pump
winn is offline
Old 01-09-2009, 10:54 AM   #9
Handle It!
Re: Melanine Finish
Good for you!!! Pictures are ALWAYS a plus here on CT!
Old 01-09-2009, 11:22 AM   #10
premierpainter's Avatar
Trade: Painting Contractor
Re: Melanine Finish
Well at least you used a great quality top coat. It should last at least until you get paid.
premierpainter is offline
Hourly Rate for Finish Carpentry in Seattle Donnie B General Discussion 33 09-05-2009 11:39 PM
EXT, finish choices genecarp Painting & Finish Work 19 12-08-2008 04:47 AM
Dirt in Finish banctecbobn Flooring 18 09-19-2008 06:19 PM
Refinishing an exterior door - finish suggestions wanted Haydin Painting & Finish Work 4 08-19-2008 10:41 AM
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 04:41 PM
