Mahogany Door Restoration
Old 02-19-2006, 07:13 PM   #1
locofoco's Avatar
Trade: general remodeling
I've got 2 potential customers needing their front mahogany doors and sidelights re-done. The sun has really did a number on them, finish is still brown but flaking and powdering.
Whats the best way to restore these without stripping to bare wood? Can I steel wool or sand them, restain and 2 coats of poly? There is some light cracking on one door, what could I fill it with that would be stainable? Is there any new products better than poly that would take more UV abuse.
Thanks!
locofoco is offline
Old 02-19-2006, 07:20 PM   #2
Painting Contractor
JMGP's Avatar
Re: Mahogany Door Restoration
Dont use Poly...
Use an exterior product such as...
Helmsman - Spar Urethane
JMGP is offline
Old 02-19-2006, 07:34 PM   #3
Painting Contractor
JMGP's Avatar
I am assuming that the "clear" finish that is on it now is flaking?
who ever did the doors in the first place probably didnt use the right product...
Steel wool isnt going to do anything for you...
To do it without stripping... you will have to do A LOT of sanding... you will probably find that sanding "alone" will remove most of the flaking finish...
Try to sand most of the finish off becuase if you are going to re-stain it... you want as much stain as possible to penitrate...for uniformity...
after your prep... apply 2-3 coats of the Urethane (exterior)... let first coat dry thoroughly.. then sand it with 220... then apply finish....
there is "stainable" wood patch... one is called Zar - wood patch... its touchy stuff though... I have found that mixing some of the stain that I will be using.. in with it then applying it... do a test with it first... its not perfect!
Joe
JMGP is offline
Old 02-19-2006, 09:18 PM   #4
locofoco's Avatar
What would you charge for this job. 36" door- 2 -14" sidelites. Door is about 40% glass.?????
locofoco is offline
Steps mahogany karma_carpentry Carpentry Picture Post 14 06-20-2007 08:03 PM
refinishing mahogany door ChuckEA Painting & Finish Work 6 07-03-2006 10:50 AM
Screened porch Mahogany floor? Justtrimmin General Discussion 20 05-09-2005 10:06 PM
