Mad Dog Primer
Old 01-29-2008, 02:29 AM   #1
toddcla2002's Avatar
Trade: Paint Contractor
Rewards Points: 75
Send a message via AIM to toddcla2002
Mad Dog Primer
Is it all that it is cracked up to be? Has anyone here used it? What's been your experience with it? I have been using a lot of XIM Peel Bond for rough wood, Sherwin Williams A100 oil primer for anything that may bleed and a zinc oxide primer for rusty metal. Will this primer will do the work that all three of these have been doing? I am only planning to use this on exteriors for now. Thank you for your response!
P.S. It is also the lowest VOC product when compared to the other three primers that I use.
toddcla2002 is offline
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task!
Old 01-29-2008, 05:35 PM   #2
PlainPainter's Avatar
Rewards Points: 250
Re: Mad Dog Primer
The stuff is the absolute bomb! I am still a diehard oil primer guy for exterior wood. I have used XIM peel bond - and it is an amazing product - but Mad Dog is the absolute king in stretchability. The way I have used it, is for homes that have been painted like 15-25 times over the last century and have built up excessive paint - seems like when you put a 'tough' acrylic latex paint over these coatings - no matter how much you prepped the siding - stuff is going to come loose next spring. What Mad Dog does is introduce like this pliable film that evenly distributes the 'stress' that the new paint film exerts over the older paint. I have used it mostly just on trim - as I haven't been able to justify it's cost - and as well, it's hard to cover up - so folks end up paying for a whole new coat of paint. My experiment for this summer will be to scrape and forget the oil primer and just use this over everything and paint. And see if you can truly cut the 'prep' time and still have a job that lasts. I have been spot priming with oil before applying this product over general areas. Although I have been using it for those horribly peeling tongue and groove ceilings in exterior porches. There I have been sanding with 24 grit - and then one good layer of either XIM or Mad Dog - and then paint. Even though I saw major tannin bleeds into either product - they both cleaned up with a couple coats of paint. I have also used for those ugly outside gas meters - this stuff sticks like crazy to that metal, and totally kills all the rust - and now you can paint without worry of that stuff becoming crackly and falling off. It's an amazing product that is overkill for many situations.
PlainPainter is offline
Old 01-29-2008, 08:15 PM   #3
regal's Avatar
Trade: painting contractor
Rewards Points: 150
Re: Mad Dog Primer
everything plain said... I used it on some old factory style windows and frame work (metal) after a once over wire brushing and it sealed it shut with no bleed. 3yrs now and the painted surface looks good!
regal is offline
primer before texture or after PacNWStructures Drywall 15 02-06-2008 04:37 PM
Primer questions rebar17 Painting & Finish Work 14 10-25-2007 08:51 PM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 12:05 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 04:35 PM
alkyd primer or not cowtown Wallpaper 8 08-10-2006 11:46 PM
At we cater exlusivly to professional contractors who make their living as a contractor. Knowing that many homeowners and DIYers are looking for a community to call home, we've created DIY Chatroom is full of helpful advices and perfect for DIY homeowners.
