Loxon Questions For You SW Guys
Old 05-15-2007, 04:51 PM   #1
lukachuki's Avatar
Hey guys,
I usually hang out over in the masonry forum but I thought I would pick the brains of the painting experts. I have a long freestanding Concrete block wall to paint and after reading through the previous posts it sounds like the SW Loxon is the way to go. Problem is I went in this morning and found they have 3 different types of loxon. I need to know which of the 3 outlined below you guys would recommend for my situation.
Let me preface by saying this wall is new masonry less than 2 months old with one side of the wall being just the exposed masonry 8" block with the mortar cut flush and the other side is parged with a heavy coat of type s mortar sponged fairly smooth. I have read on this forum about some of you having success with a one coat application using brown tinting. I'm curious which of the 3 loxon products this was. Ideally I would like to do this in one coat if possible but I know my chances are slim to none. The final color needs to be a brown called saddlery.
Here are the 3 Loxon products which have me confused. 1 and 2 seem quite similar.
I'm looking the SW Painting Systems Catalog given to me at my local SW store as I type this.
1. Loxon Block Surfacer $15.91 gal w/ 100ft coverage
My SW rep doesn't know much about this product and only has 10 gallons in stock. I'm not sure if it is tintable to saddlery brown or not and the manual calls for a topcoat. I think this might be the product that some of you says works pretty well with a one coat application.
2. Loxon Masonry Primer and Coating $22.74 gal w/ 200 ft/coverage
This is what my SW rep says she sells all the time and is what she is trying to sell me. She does say that she can tint it dark tan but will require a topcoat to get to saddlery.
3. Loxon XP Exterior Waterproofing System $30.96 200 ft/ coverage
This variety is tintable and according to the SW catalog I have it is for a one coat application which is also used as a waterproofer.
Are there any thought as to which way I should go in this. I have to place an order in the morning and I am concerned about making a monumental mistake as I'm not much into paint.
TIA
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln-
Less with the jaw more with the paw!
lukachuki is offline
Old 05-15-2007, 05:11 PM   #2
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: Loxon Questions For You SW Guys
The loxon masonry primer is what you need. You will need a topcoat. I typically use superpaint.
I love loxon as do my customers. It is a nice thick product with good coverage and holds up exceptionally well.
Good luck to you
Rich
Richard is offline
Old 05-15-2007, 06:30 PM   #3
lukachuki's Avatar
Good luck to you
Thank Rich,
Do you or anyone else have any experience with the loxon xp....according to their own literature it should be able to one coat it, which is very appealing. Or is there another manufacturer who might make something that could do this all in one coat. I know I'm sounding cheap and I guess it's because I am as this job has eaten my lunch although i'm not looking for a shortcut just a really good product that might save me some $$$.
Thanks
Old 05-15-2007, 06:45 PM   #4
My custom title
Brushslingers's Avatar
I'll agree with Rich, and yes I have some experience with XP... you won't need it unless it's a wall on your basement.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 05-15-2007, 07:05 PM   #5
lukachuki's Avatar
Did i miss a post by Brian?
Old 05-15-2007, 07:08 PM   #6
My custom title
Eh.... oh my sig, ha, had me totally confused.
Benn
Old 05-15-2007, 07:11 PM   #7
Richard's Avatar
no...that's Benn's signature
as far as the xp...never used it, but I can assure you the primer + topcoat system is awesome
are you dealing with a big area?
Rich
Richard is offline
Old 05-15-2007, 07:26 PM   #8
lukachuki's Avatar
Ok yeah I see now that it is indeed his signature. It will be about 9,000 ft2 which is why if possible I would like a 1 coat application.
thanks
Old 05-15-2007, 07:36 PM   #9
Richard's Avatar
holy cow that's a lot of area....maybe some other guys can comment on the xp...the difference would be big, but not huge if you did 2 coats
primer + finish (approx.) = $2000
just xp (approx.) = $1400
Rich
Richard is offline
Old 05-15-2007, 07:47 PM   #10
My custom title
XP sucks as a finish... would work but, for an exterior wall ... naaaa.
Benn
Old 05-15-2007, 08:13 PM   #11
plazaman's Avatar
Loxon XP on wall, Industrial Enamel on Trim
2 coats of XP on wall
1 Coat of Enamel on Trim
plazaman is offline
Old 05-16-2007, 08:23 PM   #12
Paintpimp's Avatar
Trade: Paint
Take another look at the Painting and Systems Guide. Look at the Mil thickness you need to apply for the one coat. 15 Mils wet, 8 mils dry. Double that if you want it waterproof. Do you have the equipment necessary to apply this amount of paint? If not you will be applying two coats of it. As far as the Loxon Surfacer, it is basically a creamier and easier to spray block filler. Has excellent moisture properties compared to other block fillers. If the concrete is older than 28 days and has a low ph. Use the regular Loxon primer and followed up by Superpaint. As long as you are not worried about waterproofing or being pinhole free.
Paintpimp is offline
Old 05-12-2009, 11:27 PM   #13
technique's Avatar
Sorry to resurrect this thread, but I am in a similar situation as the OP except I am worried about waterproofing and being pinhole free (cinder block basement wall, new construction). What is the recommended Lox On products for exterior in this case?
technique is offline
Couple questions from the new guy. n4rb Pressure Washing 3 01-27-2008 05:06 PM
Couple basic tiling questions fast pasquale Flooring 10 06-26-2007 02:40 AM
A first timer has a few questions (will proabably be long) Tpointin Business 6 04-12-2007 09:05 PM
Hey guys Baudman Drywall 3 08-26-2006 11:55 AM
I'm new and i have questions... Jadzu General Discussion 2 08-25-2006 07:03 AM
