Old 08-17-2007, 06:21 PM   #1
Trade: Carpentry, Remodeling
Low voc alternative to BIN??
I have an allergy sensitive client with water stains on the ceiling. Is there an alternative to Zinser BIN, (which I think is Shellac based)?
Chris G is online now   Reply With Quote
Old 08-17-2007, 06:23 PM   #2
George Z's Avatar
Trade: Painting Contractor
Try Zinsser's alkyd odorless but you might need two applications.
RONA has it.
George Z is online now   Reply With Quote
Old 08-17-2007, 06:26 PM   #3
Trade: Painter
FYI, Zinnser's Odorless is an acrylic resin in solvent. If you think you will need an alkyd resin to seal the stain, Odorless might not work. On the other hand, since the solvent is not water, it might reduce the risk of the water stain bleeding through as it drys.
DeanV is offline   Reply With Quote
Old 08-17-2007, 06:55 PM   #4
George Z's Avatar
I am not sure it's the same product,
but we don't get the orange label one here in Canada, it is green.
It works ok, but it likely needs 2 applications.
A positive note, it flashes less than the BIN if you spot-prime on a flat ceiling.
Need advice on shingle choice alternative to Elk ArnDavis Roofing 6 08-03-2007 09:50 AM
alternative concrete mixes orionkf Decks & Fencing 1 03-04-2007 02:09 AM
Alternative Heating sundogusa HVAC 3 12-29-2005 05:09 PM
Drywall alternative Teetorbilt Remodeling 21 11-19-2005 11:36 AM
Alternative uses for wood flooring. Artie Flooring 4 02-05-2005 11:31 PM
