Looking For Help On Epoxy Floor Bid.
Old 09-20-2009, 11:38 PM   #1
BLASTPRO
Guest
BLASTPRO's Avatar
Posts: n/a
Looking for a little help on an epoxy floor coatings job on an air hanger. We have been in the coatings business for a few years but mostly fuel tanks and industrial steel products. Is there a good resource tool for information on epoxy coatings. The specs require grinding the floor, acid wash, crack seal and then top coat epoxy. Thanks in advance.
Old 09-21-2009, 08:52 AM   #2
Taranis
Guest
Taranis's Avatar
Posts: n/a
Re: Looking For Help On Epoxy Floor Bid.
I wouldn't acid wash for starters, secondly minimum 2 x coats would be needed.
http://www.contractortalk.com/f11/gr...charity-64286/
www.justgiving.com/lesley-mark
Old 09-21-2009, 03:40 PM   #3
JMGP
Guest
JMGP's Avatar
Posts: n/a
www.devoecoatings.com
Old 09-23-2009, 07:53 AM   #4
Dorman Painting
Guest
Dorman Painting's Avatar
Posts: n/a
I did a 27,000 square foot warehouse job last year for fifty cents a square foot, labor only and came out beautiful. It was an insurance job and they had people clean the floor in front of me, the only thing we did was roll, roll and roll.
The situation you're getting in seems a bit more tricky, I would recommend that you use Tile Clad from SW. It's pretty incredible and sticks to damn near anything. It's a two part epoxy that you mix together and let stand for twenty minutes before applying. I can say with confidence that one coat is all you need, this stuff goes on very thick and two coats would be overkill and a waste of money.
I don't think acid washing would hurt anything, it's got to be cleaned regardless. They cleaned that warehouse floor with hot water and degreaser, worked out great. If you're buying materials and prepping, it's probably worth 1.25 -1.60 a square foot, ballparking type figure.
H&C Shield Crete Epoxy 420sully Painting & Finish Work 20 05-27-2011 03:28 AM
exposed aggregate epoxy bobbrown Concrete & Paving 0 03-13-2009 01:57 PM
Epoxy Coat on top of Epoxy Coat DiversifiedHR Painting & Finish Work 13 02-16-2009 09:22 PM
epoxy sbeck Flooring 7 10-20-2008 04:45 AM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
